How would you all like to correct your front camber?
Just do it the right way. You will never regret it.
http://www.k-mac.com/index.html
And also add a set of toe links.
My ex-crew cheif rasies BMW's. I know the bad guy.
Anyway, he is an engineer and ordered all 3 K-macs. Aka, street, street/track, and race only.
His words, not mine as I have NEVER used them.
Street, JUNK
Street/track, VERY difficult to adjust but worthwile
Track, Just that TRACK only as they are spherical bearings.
IMHO, there SHOULD be a better/easier approach.
Good luck OP
I have K-Mac bushings installed on my wagon and after 5, yes FIVE, trip to alignment shop and 3, yes THREE, bushings replacement, I still can't get them to hold. They fail under hard acceleration, first the rear Toe bushings (replaced by MB-Arts toe links), now the rear Camber bushings.
The symptoms are simple: under hard acceleration the car suddenly feel unstable, weaving left to right and after the bushing have failed you are left with a steering wheel that is not strait and even more unstable car under acceleration. This is not safe, period. My installer, ACG in San Diego, has been very patient and have worked with K-Mac to get replacement parts and my car back to the alignment shop at no cost, they even took care of the MB-Arts link when the Toe bushings failed.
But at this point, I am done, I'm going back to stock bushing and I will try to control the suspension geometry with Crash bolts and MB-Arts camber links, and a little less drop. But at least the car will go strait.
2005 E55 AMG
Ducati
I have to speak up here.
Getting more than a month out of a set of PS2s was also very nice!
Oh, connecting slides was much easier as well.
2005 E55 AMG
I ran the MBarts control arms and toe links on my 55, and was very happy with them. It took more than one trip to the alignment shop to get all my settings dialed in to my liking. Once they were all dialed in, getting out of the hole was wicked. No crazy swaying side to side and less wheel hop.
#32
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I suppose only time will tell.
#33
So far (about 4500 miles) no problem with the K-MACS (only on the front suspension). The installation was straight forward and setting the geometry was easy and precise. I'm using Evo toe links which were installed about 6000 ago. The combination provided a significant improvement in the handling characteristics. Albeit, there was a slight increase in sound transmission. Hard acceleration, with ESP off (car is fitted with an LSD) is quite stable. The K-MACS definitely tightened the front suspension and allowed me to set the geometry to what I feel is best for me. I certainly will watch the K-MACS for any premature wear based on your comments. The Evo links remain tight and show no looseness.
Do you care to share you alignment sheet if you have it ?
#34
#35
So, if camber arms are installed and used to bring rear camber into spec, will it affect rear toe at all? Does adjusting one affect the other?
Also, do the arms push the top of the tire out to correct camber or pull the bottom in?
#36
You will need adjustable toe links regardless to set and control toe in and toe out. Really big improvement especially with an LSD and ESP off.
#38
I understand that. I'll hopefully be selling the car within the next 6-9 months, so I don't want to put much money into mods. I want to correct that crappy negative camber look before it eats another set of tires, though.
