I hate being broken, but that was close.....
Well, I getting on the highway when I pulled up next to a brand new M3. Needless to say, we both looked at each other and nodded and waited for the light. So, the light turns green and we both hammer it. I instantly pulled three cars out. I looked back to see where he was at and something happened.
I don't know what it was, but the car hesitated and shuttered so bad that I had to let go. The M3 started to close the gap so I hit it again and it shuttered again.
So I quickly shut her down and got off the highway. CEL was now on and I truly thought I blew the engine. So I towed the car to Rage-Tek to see what happened. As soon as we opened the hood you could clearly see that the SC clutch bearings were almost all gone. So we figured it would be an easy fix.
I got the car back with upgraded clutch and was very happy. Until I took it out for a spin. The car seemed very responsive at this point and I decided to do a pull. I started at 60mph and hit it. I only got to 80mph before it violently shuttered and lost power. So I shut her down. The idle was so rough I thought it was going to shut off on its on. I turned it off and back on and it seemed to be normal. So I limped back to Rage-Tek.
We pulled the codes and found this:
Cylinder 5 - miss fire
Cylinders 1, 5, 6 - fuel injector circuit low
I thought to myself "how bad did I fu*k it up?". So we pulled the plugs and injectors. Did a compression test and guess what? 180 psi on all 8 cylinders. I think that the engine is very strong. I'm very happy that nothing major happened.
BIG THANKS to Jerry and Eurocharged for sending my new injectors the next day! You guys are AWESOME!
Thanks!
You have excellent compression, so internally she is definitly healthy.
If you think it was the gas, do you have to drain it and refill with gas you can trust or can you possibly treat what you have already?
Good Luck.
How did the injectors look when you took them out? Any gunk on the tips?
Aaron
Good Luck.
You know me, I'm always down for whatever.BTW Nemo is doing more test fitting now.
..... Oh man, she looked like she saw something bigger and better and wanted it.
I'll get some pics of the injectors for you.
Thank you brotha!
