Broke in to the 11's on a stock pulley :)
Old Oct 18, 2012 | 01:10 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
#53 is me So headed out to the track on tuesday weather was around 65F. Car ran really well with out even letting it sit to cool down. So i think i could have maybe done a few .10 sec faster couldn't get my B/F's to stick as well as i liked.
Really happy with the out come For what i have done on a stock pulley. Mods are: B/F Goodwrench Street drag radials, Shorty headers, E/C tune, K&N Filters, Chris carbon beast tubes, Resinator & Secondary cats removed and replaced with 3in straight pipes. Johnson pump & Bigger H.E i also did the colder NGK plugs. So hopefully with a S/C pulley maybe in the spring i can get this thing in the mid 11's. Just thought i would share with you all my success
Attached Thumbnails Broke in to the 11's on a stock pulley :)-imag0404.jpg   Broke in to the 11's on a stock pulley :)-imag0405.jpg
Old Oct 18, 2012 | 01:26 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Nice, seems like these cars can go plenty fast on stock boost with all the other bolt ons. You didn't post a pic of the slip though (or it isn't showing up for me).
Old Oct 18, 2012 | 01:31 PM
bnzuovr's Avatar
sorry just figured it out its up there. Yeah the car felt health but didn't think i would break 11's its high 11's but none the less its 11's haha and i believe if it was a bit cooler and had some time to sit i would have done a bit better.
Old Oct 18, 2012 | 01:34 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Not a bad 60' at all.. Figured your trap speed would be a bit higher than that with shorties and a tune.
Old Oct 18, 2012 | 01:37 PM
bnzuovr's Avatar
yeah the tires helped that 60ft big time. It was also nice blowing the doors out on a slightly modded cts-v granted it could'nt hook all that well but it was still nice to be out of the hole first and finish first
Old Oct 18, 2012 | 01:44 PM
GunMoto's Avatar
EG8 | E46 | W211
Awesome!!
What tires were you running? No X-pipe?
Old Oct 18, 2012 | 02:06 PM
bnzuovr's Avatar
Originally Posted by GunMoto
Awesome!!
Thanks!!!
Tires are B/F Goodrich g-Force T/A Drag Radial and yes no X-Pipe i had a X-pipe on my old 55 and feel it sounds alot better with straight pipes.
Old Oct 18, 2012 | 02:57 PM
Hulk's Avatar
A Merc
So try a H pipe then, you need something to scavenge
Good time...the colder it gets out the better
Old Oct 18, 2012 | 03:26 PM
bnzuovr's Avatar
H Pipe for more back pressure?
Old Oct 18, 2012 | 05:05 PM
kustom2k1's Avatar
03SL55
Almost 118 is a great MPH on stock boost. SC pulley could add 2/3 mph.
Old Oct 18, 2012 | 05:15 PM
Hulk's Avatar
A Merc
H pipe works similar to x pipe to scavenge gases from one bank to the other, maybe you would like the sound from the H better, in either case it's better than straight pipe because gases are probably not being pulled out completely
Old Oct 18, 2012 | 05:26 PM
bnzuovr's Avatar
Thanks! yeah was happy to see her pull hard on a stock pulley.
Originally Posted by Hulk
H pipe works similar to x pipe to scavenge gases from one back to the other, maybe you would like the sound from the H better, in either case it's better than straight pipe because gases are probably not being pulled out completely
Thanks for the input i will look in to that but ive never seen a H-Pipe on any 55k Motors. Does anyone fabricate one ?
Old Oct 18, 2012 | 05:34 PM
kustom2k1's Avatar
03SL55
If it aint broke, dont fix it. I would leave the car alone and add the SC pulley. Your car is running with some stink. Did you cut out the stock hpipe?
Old Oct 18, 2012 | 06:00 PM
bnzuovr's Avatar
yeah i guess u make a good point S.C pulley will be on hopefully by next spring. I was thinking about 3 to 4 mph top end and better 60ft would maybe pull me into a mid 11's pass. And yes the H-Pipe is out i custom built a mid section with mandrel bend 3 inch from the secondary cats just past were the resinator use to sit. I personally haven't noticed any power lose or issues with the straight pipes. My experiance with the x pipe vs the straight pipes is straight pipes sound alot more aggresive but still no drone i personally love this set up vs what i had in the past.
Old Oct 18, 2012 | 06:56 PM
Lelix's Avatar
2003 E55
Congrats, good stuff!! I just ran an 11.68 on the stock pulley last weekend!
82mm TB/EC tune, M/T drag radials, secondary cat/resonator delete, upgraded H/E.
Hulk's Avatar
A Merc
H pipe would have to be custom made and it's not hard and sounds mean
Old Oct 18, 2012 | 09:03 PM
BenzoBoi's Avatar
Super Moderator
W221
Nice run!
Old Oct 19, 2012 | 12:31 AM
bnzuovr's Avatar
Is this your current set up would love to hear how it sounds.
Thats pretty good for the mod list you have a pulley and some long tubes and you would be doing some damage.
Originally Posted by BenzoBoi
Nice run!
Thanks Bro!!!
Old Oct 31, 2012 | 11:37 PM
gazosnic's Avatar
e46 m3, w211 e55
very nice results! and the exhaust setup sounds awesome in person.
Old Nov 1, 2012 | 08:22 AM
Hellzno's Avatar
E55 AMG
nice run!
Old Nov 1, 2012 | 12:22 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
Love to see it! I've been saying all along you don't need a pulley for these things to be crazy fast.
I had a tune, shorties, stock tb grind and street tires and got my 11 sec pass.
Old Nov 3, 2012 | 04:21 PM
bnzuovr's Avatar
Thanks guys yeah very happy with the run if i would have had a bit more time for it to cool down i think i could have dont a bit better but cant complain for the mods. S/C pulley and retune coming next spring or maybe this winter i hope
Old Nov 3, 2012 | 05:07 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Super sweet
Old Nov 3, 2012 | 09:14 PM
TheOtherDodge's Avatar
2005 E55 AMG
Congrats guys on stock pulley runs!
Old Nov 5, 2012 | 04:11 PM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
You'll easily be in the low 11's with a SC pulley. I'm doing pulley, tune and colder spark plugs. Also have res/second cat delete. Stock cooling, but it's pretty cold over here at night when I usually run and the pump was replaced with the new OEM one which apparently pumps better than the first one.
Streetable terror, heh.
