Noob questions round 2
Old Oct 31, 2012 | 05:10 AM
Jakez's Avatar
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
- Is a belt wrap kit the only way to stop the supercharger from chirping and/or the car bucking violently in 1st/2nd gear? The bucking is ridiculous, embarassing, and unacceptable for a stock car IMO.. I hate that fact that I can't drive this car around town in manual mode without the annoyance of the supercharger engaging again every time I'm pulling away from a red light or a stop and possibly making the car buck/surge back and forth. Which is the reason I drive in auto 90% of the time.
- How much time needs to pass for the supercharger clutch to disengage again? Seems like I can get it to chirp on while slowly accelerating in 2nd and then drive normal for 20-30 seconds and then get it to chirp again. But I could have sworn I read on here that you have to stop for 5 mins or something before it disengages again?
- Everyone says the s55 intake tube is far less restrictive and it's only $15 to buy it. Well where can I buy that OEM piece at?
Old Oct 31, 2012 | 08:50 AM
berti_00's Avatar
2016 Cls63s AMG
Buy it at the dealer..
Old Oct 31, 2012 | 12:12 PM
Worth the wait's Avatar
2006 E55
Any mods?
Sounds like your sc clutch is failing.
Might want to consider the smaller pulley/clutch assembly that is available aftermarket.
Probably that and a Eurocharged tune would be less $ than the OEM SC clutch and give you some nice HP gains to boot
Good luck!
Old Oct 31, 2012 | 12:53 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
so you're saying that you can buy OEM parts at the dealer?
and there's something wrong with your car... mine is stock and doesn't exhibit any of the issues you're seeing.
Old Oct 31, 2012 | 01:32 PM
E55Greasemonkey's Avatar
This place is a joke.
Mine bucks in 1st gear too...really harsh.. But now that you mentioned it, maybe it's only in manual shift mode, I'll have to check it out.
Old Oct 31, 2012 | 01:37 PM
bghark's Avatar
2006 E55 AMG
Yep, there is something wrong, plain and simple. My car is smooth as silk until I jump on it. Even then, I get the chirp, like the chirp, and she engages firmly and pulls strong. Never ever any bucking issues. Go get it checked out.
Old Oct 31, 2012 | 04:05 PM
Kickem's Avatar
2005 E55 AMG
The symptoms you're having aren't completely uncommon and there are even a couple threads talking about bucking issues.
I had something very similar when I first bought my car (and it was still completely stock) except it only happened to me in 1st gear. Sometimes when I would accelerate under moderate throttle from a stop or slow roll the car would buck violently two or three times when the supercharger engaged. I took it the my local Stealer and they tried to tell me it was the transmission that was the problem but it was obvious to me that it had something to do with the s/c clutch. It was right around the time that the smaller s/c pullies became available so I bought one along with a ECU tune and between the two it completely solved the problem. So either it was the stock clutch going bad or something to do with the tune that cleared it up but I've never had a problem since. Good luck as I know how annoying that stupid bucking is....
Old Oct 31, 2012 | 04:08 PM
Jakez's Avatar
Ok thank you guys for clearing some of that up. I have a Eurocharged pulley and tune waiting to go on so I guess I will see if that cures the bucking problems.
Here another noob question: how the hell do you figure out how to remove clips and other **** on various parts of the car without breaking them first? See picture for example.
Old Oct 31, 2012 | 04:18 PM
Kickem's Avatar
2005 E55 AMG
After you take all the bolts off the top plate (of course) the one on the left hand side of your picture simply pulls straight up along with the plate it's attached to. It has a rectangular piece underneath that fits into a bracket but I don't remember anything holding it in. The one on the right requires some upward pressure to pop loose and I used a wide screwdriver on either side and didn't have any problems.
Old Oct 31, 2012 | 08:13 PM
Jakez's Avatar
Well I tried sneaking a flathead under the one on the right and a piece of it immediately snapped and broke off. aarggggg
Old Oct 31, 2012 | 11:10 PM
Kickem's Avatar
2005 E55 AMG
Did you unbolt all the other bolts on the top plate first? That whole assembly lifts up once the bolts are removed.
Old Oct 31, 2012 | 11:37 PM
Kickem's Avatar
2005 E55 AMG
Ok, I just got home and took a look at it...
There are three (3) bolts on each side of the plate that need to be removed.
Two (2) torx screws and one (1) bolt in the center that attach to the hood release assembly that also need to be removed and then the whole top plate will lift straight up. You'll need to use the screwdriver to pry from underneath the plate where the little piece that broke on you is. Those pieces remain attached to the plate itself when removed.
Be careful of the hood release cable when you go to put everything back together as it is routed under that plate and can become pinched.
