Re 80mm TB mod...
Is this little "breather" simply blocked off or ?
1 step closer to completion.
please do dyno if you can?
The wrap kit went on no problem and the belt lined up great. I've only driven around the neighborhood to make sure no CEL's or belt issues. I'll take the car out tomorrow for full testing on my 40 mile commute.
80mm TB
Wrap Kit
Phenolic Spacers
And yes,the wire can then be sucked through the TB and into the leading edge of the rotors on the SC.
The TB install is a mod that needs to be done with extreme care,not only because of the wire mentioned but also other things such as gasket sealing areas etc.
bah now I'll have nightmares of the tech just chucking out the stock TB and forgetting about this wire and gasket sealings
Non the less thanks for the heads up
You are the man........Awesome pics of your hard work.......You can see how the belt covers a lot more of the SC snout in your picture.
Looks like you got a different belt than I did with my Wrap Kit. What was the make and model. My was not a green colored belt...
No big deal on the DYNO, I will be able to document the HP and TQ gains of the 80mm TB, Wrap Kit and Spacers........
Congrats.!!!!!!!!!!!!! NOw get out there and get your butt dyno done
Roland
Very nice install Brian!! Glad it all went in without any issues.
Let me know what you think once you've had a chance to drive the car a bit..
80mm TB
Wrap Kit
Phenolic Spacers
I will put up some pics later to clarify what Im talking about.The hoses and wire that Im describing are the factory y-pipe hoses.
One car that I did the TB install on had the wire popped out and it was resting nicely up against the leading edge of the SC rotor.Somewhere down the line,either during assembly at AMG or work being done at the dealership this wire got popped out and its a good thing I found it.Its very easy to tell if the wire is in place or not,towards the middle of the hoses,there is one rib that will be stiff compared to the others.Just squeeze the hose and see if you can feel the wire or not.If the hose is soft from end to end,then the wire has popped out.Hopefully it didnt make it past the Throttle plate like this one did.
I understand all of that, but do they all need the plumbing blocks? Is that just an S thing, or any non- E55 TB?
