Rear airmatic reservoir / container - how to fix a leak?
Old Oct 31, 2012 | 06:00 AM
C32Berg's Avatar
GLK 320CDI - 2009 / SL500 - 2003
Problem: My car sit's on the rear right side after a night in the garage..
Fault finding: The air reservoir is leaking air...one way or another...(the pump & spring is OK..)
How to fix?
Plan A) ...assume the leak is at the hose connection...can I repair / seal off this area while having the reservoir still installed?
Plan B) ....go for the ultimate solution i.e. replacing the reservoir/container...can this be done w/o lowering the rear axle...
Anyone with experience fixing / replacing a leaking reservoir? All suggestions and recommendations are greatly appreciated.
Old Oct 31, 2012 | 07:42 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Replace both sides with and Arnott units. Arnott units do not require reservoirs.
Old Oct 31, 2012 | 08:37 AM
GT-ER's Avatar
2005 E55 AMG
I don't see how it can leak fron the hose since it's ultra sealed from the factory. It even seems to use some glue. In my case it was the valve inside the bellow that would get stuck open. Swap to arnotts.
Old Oct 31, 2012 | 09:22 AM
black06c230's Avatar
mgLipGD
Arnotts and be done
Old Oct 31, 2012 | 08:12 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Nice wagon. I will echo what others have said, go with the Arnott replacements
Old Nov 1, 2012 | 01:16 AM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
Beautiful wagon my friend.
Old Nov 1, 2012 | 06:05 AM
03'55AMG's Avatar
AMG
Love the wagon man
Old Nov 1, 2012 | 01:38 PM
arnottdoug's Avatar
Former Vendor of MBWorld
MERCEDES-BENZ CL-CLASS
Save 10% on Arnott Air Suspension Products!
Plus for a limited time forum members can save 10% (up to $75) by using code MBSAVE12 during checkout.
Old Nov 1, 2012 | 03:55 PM
C32Berg's Avatar
...thanks for all valuable comments ..and appreciation of my wagon...
Talking about the E55 wagon...a question for arnott, do you have a compatible solution for the E55 / S211...p/n 211 320 1225???
Old Mar 19, 2022 | 06:52 PM
eturk1's Avatar
W211 E320
rezervuarsız taktırmayın sakıncalı lastik değiştirmek için veya tamirde lifte kaldırdıklarında airmaticleriniz yuvasından çıkar ve yere indiğinde patlayabilir rezervuar sürekli basıncı dengeler ve hava boşalmayacagı için airmatic yerinden çıkmaz ve sorun oluşturmaz
Old Apr 7, 2022 | 06:18 PM
eturk1's Avatar
W211 E320
bu videoda ucuza yaptım sadece körüğü alın ve körüğünüzün elektronik beynini yeni aldığınız körüğün içine koyun for only 100 dollars each
