Where to find keyless go drivers side 744 silver front door handle
body hardware, front door, lock & hardware, handle, outside w/keyless, silver Left.
You can replace it yourself. There is a thread how to do it.
Left and right are always referenced to someone sitting in the drivers seat facing forward.
Left side is drivers side, right side is passenger.
I need to order up a replacement driver door handle also. The DIY seems REALLY simple.... If I'm reading it right, you don't even have to pull the door panel, just one T-20 torx screw hidden behind the weatherstrip that holds the handle in place.
From what I can tell the key portion of the handle doesn't even factor in to the swap. That same handle that does the rear doors would work on the fronts too. Of course left & right side will still be different.
Post up pics when you do it....
-G
-G
I'm curious to see if there will be any way to fill the hollow part of the handle with silicone to help keep water out? There's nothing to lose with the old broken handle once it's removed, so I'll probably do a post-mortem analysis on it to see if I can locate corrosion or the entry point for water in the MBZ design.
-G
