Camber Kit
Old 11-18-2012, 09:07 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Camber Kit
Need to get camber kit for my rear. Oddly enough I have positive camber so my wheels sit really off like this :
l................/
Old 11-19-2012, 12:20 PM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
lol that was pretty funny.
i need a camber kit for my rears too. but $900 for a kit is kind of ridiculous..
Old 11-19-2012, 12:41 PM
Roverron's Avatar
ML63
Depends on how many sets of rears you go through in a year.
Old 11-19-2012, 12:53 PM
djrabbi's Avatar
I go through 3 sets and thats from March lol
Old 11-19-2012, 12:54 PM
FinanceMike's Avatar
CLS55
Have you tried flipping tires side to side every 5k miles or so?
My CLS55 is lowered via STAR and I can get an easy 10k by flipping them.
Old 11-19-2012, 01:12 PM
lowprofile's Avatar
E55
Sounds like someone slid the backend around and hit a curb. Have you looked for a bent trailing arm or control arm?
Old 11-19-2012, 01:14 PM
djrabbi's Avatar
I looked at the control arm and it seems straight...
Old 11-19-2012, 01:17 PM
lowprofile's Avatar
E55
OK. Just doesn't make sense to me. Something is amiss back there.
djrabbi's Avatar
Is there a way i can see exactly? I took it to MB and they shrugged their shoulders like i dunno?
Old 11-19-2012, 01:45 PM
lowprofile's Avatar
E55
If it's minor, I doubt you will pick up on it with your eye. My guess is either a bent hub, bent control arm, or a bent subframe.
Old 11-19-2012, 01:46 PM
djrabbi's Avatar
The car vibrates over 60MPH cause of this also
Old 11-19-2012, 04:55 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
l................/
What are your actual camber measurements in degrees? I have my rear set at 2.16 deg L&R. This was accomplished after resetting the ride height about 1" lower then factory.
Old 11-19-2012, 05:24 PM
djrabbi's Avatar
I asked MB to forward me a copy.
Old 11-19-2012, 06:34 PM
Forrest Gump 9's Avatar
shrimp boat
I vote for bent lower control arm too.
Old 11-19-2012, 07:15 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Won't work if the tires are asymmetrical.
Old 11-19-2012, 07:26 PM
djrabbi's Avatar
I have the micheline PSS
Old 11-19-2012, 07:51 PM
HeissRod's Avatar
See how the tread is not the same all the way across the tire? There is a specific inner and outer side to the tread, specifically noted by Michelin. You flip that tire on the wheel and the tire is no longer functioning as it's designed; most notably, expelling water.
Old 11-19-2012, 07:53 PM
djrabbi's Avatar
Sorry its PS A/S
Old 11-19-2012, 07:55 PM
HeissRod's Avatar
Then they're unidirectional. You can swap those left to right, then.
Just don't swap the entire wheel/tire left to right.
Old 11-19-2012, 07:56 PM
djrabbi's Avatar
I am going to get it aligned at a speed shop and balance all wheels... hopefully it will fix the problem.
Old 11-19-2012, 09:00 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Agreed,I'm guessing somthing is bent as well. suspension parts typically shrink and don't streach from a impact. Being positive camber its not going to be a upper arm. A lower control arm is a cheap/easy place to start. You won't nessasarly see it being bent. A spindle or subframe is obviously more involved.
Old 11-19-2012, 09:02 PM
djrabbi's Avatar
would anyone have a part number for this?
Old 11-19-2012, 09:41 PM
Toadster's Avatar
2005 E55 AMG
that's what she said
Old 11-19-2012, 09:42 PM
djrabbi's Avatar
That is what your wife said to me, I was just repeating
Old 11-20-2012, 10:02 AM
djrabbi's Avatar
Here are my specs.
File Type: pdf
Quick Reply: Camber Kit
