RedBullJnky vs Renntech E63 BiTurbo "Teaser"
Is it safe to assume the white E63 in the video was the white E63 in this track video when it only had tune before downpipes being added? Figured it must be since the video was from PBIR which is right around the corner from the dyno day you guys did so same area.
http://www.youtube.com/watch?v=3S7c4dr6isU
http://www.youtube.com/watch?v=LiKKP0bm9OE
This videos you linked are of my friend Steve's car. Those runs were done in the heat on stock Conti's. He only has a RennTech tune. He does have the carbon ceramic brakes on his.
His goal is a 10 second car on stock tires with just a tune.
Super Moderator
#32
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
After this he added some more goodies.
http://s264.beta.photobucket.com/use...ml?sort=6&o=0#
#37
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Using the generally accepted formula, that's about 800 bhp. That said, I suspect there is a good deal of torque limiting going on. I really want to see if that 7 speed can hold up, however MB is now using a revised 7 speed in the 2013 SL65 for the first time. Personally, I would like to see a version of the SLS 7 speed double clutch. We will just have to wait and see how the early E63TT's 7 speed hold up.
#40
This run was very short and was the last of them. Wait til you see the first run. O.O
I was getting bad wheel spin until 60mph and we started at 40mph for all the runs.
That thing hauled azz though. It was fun!
#43
'05 SL65, '13 FX4 Eco
With DPs they have reached 11.5s already if not faster. There are only a few in the world in upgraded turbos right now and I've heard an 11.3 is the fastest so far.
I would assume with the 5.5TT in the amgs could see a low 11 with an exhaust and DPs. Once some upgraded turbos come out I could honestly see some guys knocking on 10s in a flying brick.
#45
#46
#50
Nothing special. 2 HEs, trunk tank, meth, and flow pattern. Specific timing for meth to spray.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Sounds about right.
I'm working. And the vids are on a different camera then the last one.
Sounds about right.
