I'm screwed 1900 job
Old Dec 3, 2012 | 01:08 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Originally Posted by Manuyc
Was your key way stuck in the crank shaft gaspam? And how did they get it out? That is where all the labor is costing the most, they have to take most of the front part of the engine to get in the crank shaft to take out the key way
mine sheared completely off and they had to take the engine out as it blew out the crankcase seal plus they needed to clean up the crankshaft snot and they pinned my new pulley to the crankshaft for extra holding power
Old Dec 3, 2012 | 01:25 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
WOW man!
Old Dec 3, 2012 | 01:30 PM
GT-ER's Avatar
2005 E55 AMG
Not keyway, but key. You're keyway is fine. Even fixing the oem key won't garantee it'll work because the oem key is ultra thin and the crank damage will make the grip even worse. Time to install a beefier key and never worry about it again.
Old Dec 3, 2012 | 01:32 PM
Manuyc's Avatar
Where would be a good place to get a beefier key?
novae500's Avatar
W211
Best to get the car towed to some Indy that you can trust <br />
If you get the dealer to do <br />
1. the friend/tech will be doing it at his cost or lower rate as stated<br />
Or <br />
2. dealer will fire him for trying to install aftermarket parts
Best of luck in getting this fixed. Just got my car back from dealer for humming noise going 30mph or more. Three days later $3500 bill for new differential. Luckily covers under warranty
Old Dec 3, 2012 | 01:37 PM
Manuyc's Avatar
He tried to get it lower on the rate the best he got was 90 from 130. when I get there i will try to drop another couple hundred bucks
The whole process of taking the car to another shop will be more time consuming, plus I want them to fix it so when I take it from them and something goes wrong they have no choice but to repair it for free.
Old Dec 3, 2012 | 01:42 PM
  #32
chawkins2001's Avatar
2006 E55 AMG
Sheesh, there is alot of incorrect information been thrown around in this thread.
Good luck with your fix man, let me know if you need any help.
Old Dec 3, 2012 | 01:43 PM
  #33
novae500's Avatar
W211
Make sure the tech if he knows how to weld another key way or pin the pulley. If he doesn't your just paying for them to pull engine to get the part out??? And how are they going to fix once the part is removed. Just hate to see you get billed and car still not fixed
Old Dec 3, 2012 | 01:50 PM
  #34
Manuyc's Avatar
I pm you my number please give me a call and advice me sir!
Old Dec 3, 2012 | 02:10 PM
  #35
gaspam's Avatar
WOW
That is just not right man, thats BS if you ask me. Let me get this straight, you take your aftermarket pulley to a certfied MB tech, have them install it. They install it, and when you take the car out for a test ride, it comes loose immediatly and shears the keyway?
Let me ask you this question, did the pulley you put on have an OEM MB hub?
this does not have MB hub pressed on as its the new 172M asp pulley style, its the new one ASP sent to me after i sent in my old one for warranty
the tech did not torque it to correct spec... he stated 190 + 90 degrees which is not correct... it should of been 275+ 90 degrees.
the tech torqued it as if it was a kleemann/ renntech pulley which will not hold an EC/ ASP pulley on the crank
Old Dec 3, 2012 | 02:17 PM
  #36
Manuyc's Avatar
Thanks Craig's for your phone call and help, much appreciated
Old Dec 3, 2012 | 02:18 PM
  #37
Manuyc's Avatar
Im just going to put the stock one back on.
Old Dec 3, 2012 | 02:31 PM
  #38
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Not all Mer techs are good. Many know less than someone here. They are more book than mind.
You might have a wrong "kinda friend"
You went to a wrong dealer/wrong tech
Now you have the one who broke your car fix your car. Just wrong!!! What if they break more and claim because they try to fix your issue, other stuff fails and now bill comes bigger?
Just all wrong. Good luck!
Old Dec 3, 2012 | 02:50 PM
  #39
clkwork's Avatar
CLK63 Black Series
Dang, that's a 1-900 job for sure. Good luck with the recovery.
Old Dec 3, 2012 | 03:01 PM
  #40
Manuyc's Avatar
Ty
Old Dec 3, 2012 | 03:13 PM
  #41
black06c230's Avatar
mgLipGD
Craig is the man to contact on these types of issues, he won't lead you wrong!!! He has helped me a ton on my mods.
Old Dec 3, 2012 | 03:17 PM
  #42
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I've never heard of a keyway being welded. Something I'm missing here? I'd look at someone like they were crazy if they told me they intended to weld anything to do with my keyway.
Old Dec 3, 2012 | 03:24 PM
  #43
Manuyc's Avatar
Old Dec 3, 2012 | 03:25 PM
  #44
Manuyc's Avatar
Save me from a bigger headache I'm just going to put the stock one back on
Old Dec 3, 2012 | 04:01 PM
  #45
e55amgrocket's Avatar
Dirt Scooters
Yea don't know what he's talking about with welding a key way back on. I'm still waiting to get my crankshaft back from having another snout welded on and balanced again.
Old Dec 3, 2012 | 04:03 PM
  #46
Manuyc's Avatar
Dam!
Old Dec 3, 2012 | 05:44 PM
  #47
e500slr's Avatar
2011 E63, 2013 CLS63
God I would be PISSED if they did that to my car. You make them pay and repair it for free mate no matter what it takes. Don't play this weakly, you make it clear that you're not settling for anything other than a great result and a proper repair FOR FREE!!
Old Dec 3, 2012 | 06:15 PM
  #48
novae500's Avatar
W211
<br />
<br />
I guess what I meant was the "key" not keyway. What gtr did w his fix that slotted piece that he made from scratch that was longer and thicker than our stock one.
Old Dec 3, 2012 | 06:40 PM
  #49
Manuyc's Avatar
Yea! I m just going to out the stock one back on
Old Dec 3, 2012 | 08:04 PM
  #50
nicco's Avatar
E55 AMG
If they werent gonna honour their work cause it was a aftermarket pulley or cause you brought it in they shouldn't have installed it !!
