ECU tune too rich smell burning
Old Dec 18, 2012 | 02:40 PM
kompressede's Avatar
Sold - 05' E55
Put a gauge on the car and see what the AFR reading is. No cats will give a rich smell also.
Old Dec 18, 2012 | 03:17 PM
lowprofile's Avatar
E55
Originally Posted by groove66
Mechanics logic is not totally off base(As far as increasing boost to lean it some) But it's the Kleemann tune. That would incline that the tune was not optimized for your car and mods you have, not what you are gonna put in down the road.
I am getting a Emmisions failure at idle on my K-4 tune. so this time it going on a dyno and no one size fits all chip..
To put it simply, increasing airflow would only lean out the mixture if the fueling was stuck at a fixed value, which it is not. Adding boost would put you on a different part of the WOT fueling map.
As PACougar pointed out, Kleemann is not going to change the target AFR for closed loop operation.
Old Dec 18, 2012 | 03:22 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Where in dash you guys install the AFR gauge ? and which one ? there are so many with AEM.....
And what's the right ratio ? 12.2 stock ?
Old Dec 18, 2012 | 03:36 PM
lowprofile's Avatar
E55
A lot of guys, including myself, use the Dashdaq/zeitronix combo with a windshield mount.
Old Dec 18, 2012 | 08:47 PM
groove66's Avatar
2005 e55
I see. Just getting into these cars not sure how the ECM strategy works..
I was assuming they ran of an open fuel loop with a closed loop for idle and economy.
Old Dec 18, 2012 | 08:52 PM
groove66's Avatar
2005 e55
Originally Posted by PACougar
If you're getting a failure at idle, it's unlikely it's a tune issue. I doubt Kleeman makes any changes whatsoever to the idle tuning, unless you have cams and perhaps not even then.
I do have their cams. but I am checking all breather hoses, replacing valve cover gaskets, plugs.
I did get a MAP implausable code.
Old Dec 19, 2012 | 10:59 PM
  #32
E55Greasemonkey's Avatar
This place is a joke.
Charly this smell is normal since your primary cats are gone. I also have Kleemann headers, and was just dyno tuned by Eurocharged and mine smells the same after a hard acceleration.
Old Dec 20, 2012 | 12:12 AM
  #33
layzie12g's Avatar
2008 Mercedes Benz E63
Even when your drive a bone stock car hard it makes a burning smell from the cats getting ultra hot.
If you do not have cats it all, of course the car will "smell rich". Especially when its just idling. They stink.
Old Dec 20, 2012 | 12:59 AM
  #34
The Kleemann headers leave the secondary cats in place, of course they are not as effective as the primary cats since they never get as hot.
Old Dec 20, 2012 | 01:59 AM
  #35
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Just run leaded race gas all the time, your exhaust will smell wonderful!
Old Dec 20, 2012 | 03:26 PM
  #36
CharlyE500's Avatar
Thanks man ! I think you are right. Since I installed the header and pull hard then the burning smell. I guess I was paranoid when my mechanic test drove it. Just thinking if need to upgrade the SC pulley. According to Kleemann my tune is good up to Crank pulley 172m boost so I think I should be fine.
Old Dec 20, 2012 | 05:28 PM
  #37
johnnyblaze's Avatar
CLS63S
I wouldn't worry too much about lower pullies. The most recent failure is just fresh in everyones heads but hasnt happened enough to make me want to advise anyone against a lower pulley. (unless you dont have a trustworthy shop) You live in So Cal. Take it to Benzworks and have Serge do the install. I drove my car hard for nearly 10k miles with a 180mm ASP on it. Never wobbled, threw belts, or squeaked.
