Strange knocking noise from top of engine / supercharger???
Old Dec 24, 2012 | 11:03 PM
  #51
Jakez's Avatar
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
Originally Posted by 03'55AMG
This takes *****. I've always wanted to pull the s/c, never had the shnuts to try it. Random question that may help others in the future, can somebody effectively name off EVERY tool necessary for this kind of job? Ill check WIS later, but not everyone has WIS
I think the tools necessary are least important.. IMO. I just need to know exactly what is required to be removed or disconnected. And a pic or two with arrows pointing to what/where to disconnect would be a godsend.
I figure the hardest part is getting the supercharger center bolt off. I went to harbor freight and bought a $50 electric impact gun with ~250lbs ft tq, 15/16 socket, impact swivel, and a strap wrench. I heated up the bolt with just a heat gun for a few minutes and then hit it with the impact for a good 40 seconds straight and it came right off lol. Then again my supercharger bearing has been replaced before so the bolt is probably easier to come off.
Old Dec 25, 2012 | 12:20 AM
  #52
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
You don't need to pull the clutch off to get the Screws out of the SC.
Old Dec 25, 2012 | 06:15 AM
  #53
GT-ER's Avatar
2005 E55 AMG
X2
Old Dec 25, 2012 | 09:07 AM
  #54
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
What Info are we missing here
So The OP removes the everything from the Throttle body to the air filter boxes ? Or does he leave the Y adapter in place ? . Getting those rubber bellows off the Y and or the air filter boxes is a pain in the butt. The Oetiker style clamps are hard to remove . The bellows are stuck to the the Y and or the air filter boxes. So you flex & twist the Bellows to get them off?
Inside of the bellows is a Oval steel support ring . It is not molded or glued in place. just sets in a shallow groove to keep the bellows from collapsing under hi throttle openings. Twisting the bellows will dislodge the steel ring . It will make its way through the Throttle body. goes to the blower rotor blades .
the inter-cooler will catch some of the debris , but much of it gets blasted back toward the throttle body intake manifold , the the bypass valve opens up !! end of Story . I've seen this twice in the last 6 years.
Cheers _PTEngineering
Old Dec 25, 2012 | 10:39 AM
  #55
Jakez's Avatar
Holy crap I'm an idiot HAHAH. You're right... I don't know what I was thinking. Oh well, at least I know I can get that sucker off.
Going to take a further stab at this later today or tomorrow. Everyone have a Merry Christmas!
Old Dec 25, 2012 | 10:44 AM
  #56
PACougar's Avatar
Don't doubt yourself and remember we're always here to help. Have a good Christmas!
Old Dec 25, 2012 | 10:32 PM
  #57
GT-ER's Avatar
2005 E55 AMG
x2
Old Dec 26, 2012 | 02:52 PM
  #58
Jakez's Avatar
Christmas is finally over woohoooo. Going to take another crack at this soon here. Any tips on removing old hoses without messing them up? It looks as if they're going to crumble away if I try to work them off with a flathead or rip apart if I tug too hard..
Old Dec 26, 2012 | 07:46 PM
  #59
GT-ER's Avatar
2005 E55 AMG
I usually pry around the orifice of hoses with a small screw driver to break the seal and then pull on it. Careful with vacuum hoses, they may become brittle but are cheap to fix if they break.
Old Dec 26, 2012 | 07:59 PM
  #60
PACougar's Avatar
Also, if there is plenty of slack in them you can always use a razor and slice them off the cut them flush for reinstallation.
Old Dec 26, 2012 | 09:43 PM
  #61
GT-ER's Avatar
2005 E55 AMG
OR...just eliminate them like I did.
Old Dec 28, 2012 | 01:10 PM
  #62
Jakez's Avatar
4 bolts for the supercharger on each side? Looks like theres a 5th one on each side in the back..
And do I need to pull the injectors?
Old Dec 29, 2012 | 10:28 AM
  #63
GT-ER's Avatar
2005 E55 AMG
I believe it's 5 bolts on each side.
Old Dec 29, 2012 | 09:10 PM
  #64
PACougar's Avatar
I think it's 5 as well if I remember correctly and no you don't need to pull the injectors.
Old Dec 29, 2012 | 10:10 PM
  #65
03'55AMG's Avatar
AMG
OP, if you post pictures along with what you are having trouble with, a lot of very smart people will walk you right through it. Believe me, the willingness to help is contagious around here, lots of great guys willing to help.
Old Dec 30, 2012 | 07:50 PM
  #66
Jakez's Avatar
Ok she is running again. I towed the car to the shop yesterday and basically spent the entire day learning how to remove/install the supercharger. When we pulled it off and looked inside there was a damn pile of shredded rubber/plastic/metal. No idea what got in there.. but I sprayed almost 3 cans of brake cleaner, wd40, and an air hose through the supercharger rotors while I held it upright and slowly spun them until I couldn't see any more shavings falling out anymore. The video is pretty much showing what it looked like right after the pile of stuff was removed before I cleaned it all out. Opened the cooler and there was a bunch of junk in there also but it looked pretty clean on the other side. How bad does the damage look in the video?
We did have to pull the injectors and flip the entire fuel rail over to the side out of the way. When I first started her up there was a bit of ticking left and it still sounds rough on a cold start but I think it's worked itself out now it sounds pretty normal. There was only a tiny bit of rubbing left in one spot when I put it back on and I couldn't figure out what it was so that was the furthest I could go with cleaning it out.
So thankful for the guy running the shop I go to. He basically had me do all the work and helped me with what I couldn't or didn't know how to do. I know I can remove/install this thing myself now, minus the lifting lol.
I thought about that.. but I know there are hoses and stuff in areas where I can't really get a pic, and also wasn't sure of where to take pics and what of... maybe next time lol.
Old Dec 30, 2012 | 08:19 PM
  #67
Critter's Avatar
07 E63 + 07 CLK63CAB
Success, congratulations on you recent project. You are lucky that the piece that went thru the SC did not hold the throttle open instead, could have been a big problem trying to slow down. Again good job. As you already know never run without air filters again.
Old Dec 30, 2012 | 08:23 PM
  #68
Jakez's Avatar
Thanks Critter
Does anyone know the correct route for this vacuum hose? It's blue and goes to the top of the supercharger. We put it on next to last and... yeah... lol.
Also, my a/c and heat suddenly stopped working now... wtf?
Attached Thumbnails Strange knocking noise from top of engine / supercharger???-50.jpg
Old Dec 30, 2012 | 08:59 PM
  #69
GT-ER's Avatar
2005 E55 AMG
You should have removed the rotors to clean them out better but as long is running good again then it is what it is. Glad you got it fixed.
Old Dec 30, 2012 | 09:31 PM
  #70
PACougar's Avatar
+1, If it still sounds off a little, it's super easy to pull the rotors out. You were about 5 mins from having them out and there's nothing special needed to remove or install them.
Old Dec 30, 2012 | 10:13 PM
  #71
Ironcross's Avatar
E55 AMG 2003, SL55 2004, 2014 E63 Renntech (Current), 2018 renntechE63 (Current)
Flat bed to the shop ! Do not start it again !!
Old Dec 31, 2012 | 03:29 PM
  #72
Jakez's Avatar
Does anyone know the size of the lower coolant hose on the left side that had to be disconnected? It rubbed on a pulley and cut a hole in it. Trying to find a same size hose so I can just cut it and use an adapter to just replace the area where the hole is.
Or a part number for the entire hose would be awesome. Cant find it on parts.com
Old Dec 31, 2012 | 03:45 PM
  #73
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
3/4" heater hose should do the trick
Old Jan 2, 2013 | 12:02 AM
  #74
Jakez's Avatar
It was 5/8" :P
Chopped about 4-5 inches off and replaced the section with 5/8" hose and an adapter. All good now
Old Jan 2, 2013 | 01:34 AM
  #75
overZealous1's Avatar
sl55 amg
Thanks Critter
if it is the one i am thinking of, it routes under the blower. maybe a coat hanger could make it under, then tape line to it and try to pull it through underneath. not a big deal though if you don't mind seeing it on top.
