Is the stock 02' E55 springs lower than stock 00' E320?
if so How much lower is it?
I'm considering getting the stock E55 springs for my E320.
thanks
also, be sure to use #1 spring pads all around
I'm looking for about 1" drop only.....
also, luke from tire rack said that if I get the E55 springs, it will actually raise the car because the E55 springs are meant to support the V8...
https://mbworld.org/forums/showthrea...threadid=48495
what do you think?
how much lower is that? and did you chang your shocks as well?
what do you think?
Luke is wrong. The drop isn't much, but it is lower.
should I go Eibach springs($265 new)? or should I just get the E55 springs on Ebay (only $80)... ?
All I want is about 1" drop.
I don't plan to replace the shocks yet.
what you think?
KWik, Your ride looks sweet!
what you think?
If I was doing another E, I would probably get Vogtland or Eibach springs with Koni adjustable shocks. This way I could just change pads if I decided I wanted a little more drop.
the front is good with 1 finger clearance..
but the rear is too low 1/2 finger... and it looks like this // \\...
what to do now? I want to raise it up at least 1 1/2 finger clearance for the rear...
help!!!
