X-pipe eliminates exhaust drone?
Resonator and muffler delete = ear bleeding drone!
Magnaflow tru-x fits perfectly in resonator location (see pic) but does very little to eliminate drone.
"J" pipes installed in the location of deleted mufflers eliminates all drone and car has incredible exhaust note. One of the other members here pointed me in the right direction but I can't recall who it was now. If you search for "J pipe" you should be able to get some great info on the subject.
Regards
Regards
I am assuming you deleted your 2ndary cats and all that oem H piping by the transmission?
Smog management is strict here in CA so I don't want to mess with cats.
Would you please show us pictures of your exhaust set up, and detailed location and dimension of the J pipe?
Please!
Looking forward to your J-pipe photo.
The circled area and arrow show where the J pipe is split off from the rest of the exhaust. As you can see, it parallels the exhaut pipe for a bit before it curls up into the void where the stock mufflers used to be and is capped at the end. I couldn't really measure the overall length of the J but looked back at some of the other posts regarding this setup and it looks like 29" was the preferred length. I tried to get a better shot of the actual J pipe itself but the rest of the exhaust is blocking it and without it being in the air this is as good as it gets. Hope it helps.
Thanks!
