X-pipe eliminates exhaust drone?
Is it true?
Please, share your experience of eliminating drone with X-pipe.
*Mr OP said no mufflers. So I will stick to my original comment. X-pipe will not stop the "drone"
OK ... the conclusion is X-pipes don't eliminate drone completely but helps a little ... right?
Actually, I have stock exhaust system except Super sprint mufflers, which makes slight bearable drone. I prefer the following set up because I really want more sound.
Stock primary cats -> X-pipe (2nd cats delete) -> Straight pipes (resonator delete) -> Super sprint mufflers
But I don't want more drone ... so, I'm thinking of the following exhaust options.
1) Stock primary cats -> X-pipe (2nd cats delete) -> Stock resonator -> Super sprint mufflers
2) Stock primary cats -> 2nd cats -> X-pipe (resonator delete) -> Super sprint mufflers
What do you think about the above options?
Which option will make less drone? Comment please!
I later deleted my mufflers. I loved the sound but their was alot of drone. I was ok with it but my wife did not. I then replaced the resonator with borla pro xs mufflers. The result is a perfect. There is nominal drone just like when I was all stock but with kleeman headers/downpips. I have the best of both worlds from his setup... nominal drone inside and great exhaust sound on the outside that I love to hear. Now my exhaust is: kleeman headers->kleeman downpipe (which deleted the primary cats) ->the stock secondary cats and stock H pipe exhaust setup down by the transmission-> borla pro xs mufflers-> stock exhaust tips.
Good luck OP.
Good luck OP.
Is this what you said?
http://www.borla.com/products/proxs_...t__400286.html
You mean Tru-X perforated core muffler?
http://www.magnaflow.com/02product/s...=main&id=10735
Is this correct size?
Otherwise please recommend correct size.
Good luck OP.
I have Kleeman headers with no cats.....at all. Magnaflow x-pipe with resonator delete. In line dual 12" SS resonators to the factory mufflers. I've been buying my resonators from this guy out of Indiana for years.
Not much drone. Kinda Nascar, though. lol
http://www.ebay.com/itm/STAINLESS-ST...28d9af&vxp=mtr
It's when you have 3" custom piping where it can be time consuming to cut and fit and weld
I had a custom 3" H pipe made and recently changed to the x pipe much better for our platform
