lousy video kills tires really fast
E55 w/ goods, Z32 Project underway
Seems to be a certain twist in physics which draws cars to poles and trees, even if the only one on the side of the road. Just saying. But I like the video. It this a light weight tc or just a stall change?
Sounds nice, it makes you wonder why guys change the way the exhaust sounds. The last couple of times at track people are shocked because I have a very quiet car that happens to run 10's sure my burnout is loud but that's mostly the SC/DR's screaming and when I take off it doesn't sound like much compared to other cars at the track
99 ford lightning
now if i do the long tubes i will keep high flow cats on with res and stock mufflers. you can feel the car rev up quicker in park too now. heres a noisy blower
http://www.youtube.com/watch?v=WSmcs_fQkl8
PLATINUM SPONSOR
That near stock E55 is flying! Take a video of inside the cabin , so we can see the tach and how much less the rpm drops on each shift. Sounds like you are not dropping below 5K in the vid.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
