I think I am SCREWED
I postponed the oil change to wait for a blackstone labs test kit to come in the mail to have the oil examined. I hope its nothing, but I am worried..
. Thoughts??
just kidding - hope all goes well - maybe just some odd flashing that wore off - the labs will tell you some of the story. Any weird sounds or behavior from the engine?
None showing the shavings, there too small I think.
The shavings are like a yellowish gold color, and vary in size. Most were on the outside of the filter, and some on the inside. There were also some in the canister that holds the filter and assembly.
I really hope I am not down for the count, I will most likely be the first person ever with a fail at 80k on a stock motor...
Well sorry to say but its the life of a used car owner and it isnt necessarily just an MB thing.
This one is of shavings and looks to be dirt in the bottom, I could not get my cameras focus to co-operate, but it is visible.
This one is of the large chunk. It IS indeed magnetic. First is a picture of it, then the second is with lighting showing how big it is.
Here is my oil now compared to new.
The tip of the Qtip was a spec I tried to grab, but it fell apart like dirt. Kind of sandy in the texture of it, and it smells like burnt oil, really bad.
This one shows my current oil filter with about 7500 miles on it (right) next to a brand new filter I ran in the car IDLING, never moved, for about 10 minutes.
And in the meantime, I ordered a few more oil filters, and some parts I needed from autohausaz.com. I plan on running the engine for a while after the oil change, and swapping it out every few hundred miles to make sure nothing more circulates into the engine.
And in the meantime I went ahead and got myself some stuff to do while the Beast is down..
Hopefully this is just some crap that appeared from a weird reaction to the oohss and ahhsss from am amg at WOT... All kidding aside, I am hoping for the best at this point, I already found a 60K mile engine out of a cls55 for under $7,000 in case of the worst scenario.
EDIT:
Here are some pictures of the oil filter torn apart, it had a LOT LOT LOT of junk on the outside, not so much in the inside.. This is the only way I can show how much on the outside.. Last 4 are filter. First two outside, last two inside of filter.
Hopes just lifted significantly! My tire place just called and told me my wheels will be in today or tomorrow! I really needed that too! Looks like the conversion should be starting shortly..
