Anyone do heatercore mod to chill water ?
Basically you use a ubend pipe so you dont pump anymore hot water from engine into your heater core. Then you route your IC water to the heater core. To chill the water you just set your temp all the way up and turn the AC on. Voila ! Chills the water
I made ten passes on my GTO (maggie) and the last four were within about 15 minutes. My trap speed never dropped at all ! time before I needed to do atleast 30-40 minute cool downs between runs to not lose MPH. Input ?
Honestly, a trunk tank is probably the best solution. Drain, add some ice, and you are on your way.
I ran it on my GTO for about 8 months. Doent get that cold here in Ca so no heater isnt a big deal most of the time.
Interesting idea with the heater core. I would be interested in IATs before and after the a/c is tuned on. Anyone know the capacity of the stock heater core?
Aaron
Did better than when I was trying to pack ice in it the time before and had less boost.
you do have AC just not heat. Simply turn the temp down to cold.
