How much HP / RWHP is my car producing? 08E63 with some tune.
Roughly how much crack HP and RWHP do you think my car is producing?
08 E63 with Eucrocharged ECU tune+BMC filters+Shorty Header(PLM)+ Secondary Cat delete. with Stock 18" wheels.
I am thinking around 470RWHP range and at the crank it should be around
540~ 550 range????
Im thinking off adding Evosport crank pully for additional 10+ Hp and a set of
lightweight 18" forged alloy wheels that weigh 18lbs front and 21lbs.
Lightweight wheels should make my car move a bit faster right?
I'm just worried that these wheels turns out to be not worth the money,
since E63 is a fat *** sedan ~
Any thoughts will be appreciated~!! Drive safe ~
to put the car into dyno mode which involves some twitching. I live around
S.F bay area and I was only able to find three places. One place was definitely
good ~ they did the dyno day when Eurocharged was here in bay area. However
couldn't find the contact info. Two other places I found , I dont think they know
how to put the car into dyno mode.
Plus I am just curious then getting a actual fact. But then again dyno is never
same so might as well just speculate and save $200 .
Am I being too cheap~? My front rotors are due soon so trying to save every penny ~
to roughly estimate ~~ how much I making ~
yes $75 is doable. Fremont has one, Hayward has two. But since op is in sf. The shop op mention may charge $100. But $200 is too expensive.
How will the crank pulley add 10hp?
540~ 550 range????
