Diagnose Secondary Air Injection, EGR, and Post Cat 02 Sensors through SDS
Old Mar 19, 2013 | 11:43 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I would check your vacuum lines. Sounds like you have a leak. Especially check the metal hose that goes in beside the TB that is fed off of the valve cover. That one seems to be the most common culprit.
Good luck!
Old Mar 20, 2013 | 08:22 AM
GT-ER's Avatar
2005 E55 AMG
Does anyone know the purpose of the blue check valve that goes in the vacuum lines to the switch valve? I reinstalled my SAI and can't find the check valve but installed the system without it and can't see why the valve would be used to begin with.
Old Mar 23, 2013 | 04:26 PM
Hulk's Avatar
A Merc
Turned off sec pump, worked great
Old Jul 16, 2013 | 02:44 PM
I Like Soup's Avatar
2003 E55 AMG
I've done a fair amount of driving and I still have the evap and secondary readiness monitors as incomplete. I need these two to show ready so I can go fail a 2nd time to start the inspection waiver process. Any ideas? I had supposedly turned off the secondary as per the instructions in this thread.
Old Jul 16, 2013 | 09:54 PM
groove66's Avatar
2005 e55
the 02's need to be enabled in the tune from OE and disabled in star... just went through this recently. Got a tune and my rear 02 readiness was "not ready" And just a few weeks before the were "ready"
I talked to the tuner and he told me to do the coding. well pulled out the star went to disable and they were disabled already. went back to tuner and told him, he sent me new file with 02's turned on and rear 02's disabled in STAR and readiness was complete on the rear 02's in minutes...
Old Jul 17, 2013 | 04:06 PM
2003 E55 AMG
My secondary air monitor just got the ok readiness, so all I have left is the EVAP control monitor to trigger ready.
My O2's are showing as ready, so I have no idea what to do there. Jeremy reflashed my ECU while he was in the Middle East, but the CEL with the P2098 came back. I'm borrowing STAR this evening so I'm going to root around and see what I find.
Old Sep 21, 2013 | 07:33 PM
  #32
showmethefaacts's Avatar
2006 C230
2006 C230 shows code PO 410
Check engine light is on. Auto parts store tells me I probably need to replace the MAP sensor. I can't get the vehicle inspected with the "check engine" light on. Any clues? Thanks
Old Sep 21, 2013 | 08:15 PM
  #33
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
I suggest you start a new thread in the correct section of the forum, you'll have a lot better luck getting help.
Old Sep 22, 2013 | 10:01 AM
  #34
cij911's Avatar
one car at a time
For those of us in Cali with headers, which O2 sensor do you want to disable / turn off so as to not get a check engine light (and pass emissions) - is it the post cat O2 sensor ?
Why turn of the others - EGR & Air pump (are folks really removing these) ?
Old Sep 22, 2013 | 03:40 PM
  #35
SavMan's Avatar
2004 E55K AMG Wagon
Yes post cat, in STAR it is
Motor-Code E/A 1, LS-hinter KAT-Diagnose aus
roughly translates to behind/post KAT diagnose off
Old Oct 5, 2013 | 04:44 PM
  #36
chawkins2001's Avatar
2006 E55 AMG
I am about to try this with star, as I have two in completes which are o2 sensor and o2 sensor heater. I have put 300 miles on the car and still won't get ready.
Performing the post #1 procedure disables that parameter in the ecu completely so it shows ready or n/a?
Old Nov 7, 2013 | 04:32 PM
  #37
JoeNobody's Avatar
Mercedes
Meh
Old Nov 11, 2013 | 10:04 PM
  #38
JoeNobody's Avatar
Mercedes
Meh
Old May 21, 2014 | 09:07 PM
  #39
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Sorry for the thread revival
Originally Posted by pearlpower
Interesting, each and every time, this: Yes, engine was on.
Pearl power, what is the missing step as I am getting the exact same error you got?
Thank you sir.
Old May 24, 2014 | 01:06 AM
  #40
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
2.8 vs 2.7
Shardul,
I believe the controller for a S600 NA V12 is a 2.7, not a 2.8.
The menu access for that one is somewhat different, as I found out last year.
Old Jun 4, 2014 | 02:13 PM
  #41
nanayaw6's Avatar
Bump for response from PP.
Old Aug 18, 2014 | 12:15 PM
  #42
thumper823's Avatar
04 E55
i have tryed this over and over probably 6 times.. key on, engine running, codes cleared.. and keep coming up with this error "At least one coding setting is invalid. Check and correct coding setting." and then i click ok and ALL of the parameter's show ----.
the ECU in my car was repaired about 8 months ago due to water damage. Shardul is thinking that maybe the ECU is "Locked"
has anyone else run into this problem and found a way around it???
Old Aug 24, 2014 | 02:30 PM
  #43
forcefed4door's Avatar
05 E55, 06 Audi S4
Mad props to this tutorial. I turned off egr and air injection due to the cel. Saved me time and money trying to diagnose. At first I had same problem when I loaded the code page, all the fields were black with -----. I turned off car and reloaded das. When I got back to the page all the fields were mysteriously filled. So I switched the two and good to go no more cel.
Old Nov 20, 2014 | 07:10 PM
  #44
KnoxE55amg's Avatar
2006 E55 AMG
Ok guys, just received my Star diag today. Trying to turn off rear 02 sensors and keep getting error code like 1 posted above. No codes stored and car is running. Any help would be very appreciated.
Old Nov 20, 2014 | 07:59 PM
  #45
KnoxE55amg's Avatar
2006 E55 AMG
Once again Shardul saved the day!!! Thank you!!!
Old Nov 21, 2014 | 10:05 AM
  #46
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Glad to help. PM if your system is not allowing you to access the coding functions
Old Nov 21, 2014 | 10:45 PM
  #47
KnoxE55amg's Avatar
2006 E55 AMG
Man this is a whole new car. Can't believe how choppy it was driving. Wide bands would fluctuate between 14.6 and 15.2 cruising now steady at 14.2. Full throttle fluctuated also. Now at 12.2 steady. Much smoother drivability.
Got to turn off rear 02's, EGR, secondary air and do -10deg mod.
Thanks Shardul!!!!!!!!
Old Nov 21, 2014 | 11:14 PM
  #48
shardul's Avatar
set the RON rating in the ECU to base so it learn the octane rating from the feedback of the knock sensors
Old Nov 21, 2014 | 11:31 PM
  #49
KnoxE55amg's Avatar
2006 E55 AMG
Lol. If I can figure that out. I'll send you a p.m.
Torque converter going in next week! Need my tcu tune next!!!
Old Nov 22, 2014 | 09:12 AM
  #50
cij911's Avatar
one car at a time
Anyone have STAR in OC and want to make a few $$ ?
