EBC Brake pads
Old Mar 15, 2013 | 01:18 AM
FromM3toAMG's Avatar
07 E63
EBC Brake pads
Does anyone have any experience with EBC brake pads? the EBC Yellowstuff 4000 High Friction ones?
or can anyone suggest high quality low dust pad?
Old Mar 15, 2013 | 01:25 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
what I posted here a while back
Porterfield>Akebono>EBC Reds>OEM. All with new rotors.
EBC REDS-'New' formula so I was told.
'Noisy' as hell first 500 miles until the bedding process is complete. Quiet after.
Destroyed rotors. Hot spots, cracks, etc. Replaced after 10k miles or so. Google this.
Good high speed braking.
Similar to OEM cold braking.
Would not buy again
AKEBONO
Good overall pad
Very low dust
Less cold braking vs. OEM
Good high temp/speed braking
Little fade but still fade through a hard 40 mile canyon run.
Cheap to buy
Good on rotors
PORTERFIELD R4S
Best 'performance' pad period I have tested out of the 3.
Little noise breaking in but nowhere near the Reds. Quiet now with rare occasional squeal.
Low dust, but more than Akebonos. Still far less vs. OEM
Less cold braking vs. OEM and Akebono-tad
Never faded on me in hard canyon driving
Good on rotors, though might be a bit tougher than Akebonos.
My opinion.
With the other two options below, I would not run OEM or EBC Reds again. Once you have tried them below, you will understand.
For overall driving-no track, some canyon runs-Akebono, plus their cheap. Fade at the extreme.
For harder use and minor track and continued high speed braking. R4S Porterfields
FCP is a good shop, hunt around for the readily available 10% coupon codes.
Old Mar 15, 2013 | 01:30 AM
07 E63
Would not buy again
AKEBONO
Good overall pad
Very low dust
Cheap to buy
Good on rotors
PORTERFIELD R4S
My opinion.
Thanks, do you know if Hawk makes pads for the 63? i used them on my M3.. loved them.
Old Mar 15, 2013 | 01:33 AM
pearlpower's Avatar
I have run Hawk HPS in several vehicles, but n/a for the W211 chassis. The Akebonos are comparable to those.
Old Mar 15, 2013 | 01:38 AM
07 E63
I see, thanks i appreciate the information.
Old Mar 15, 2013 | 02:05 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Please note you got advice from an E55 driver. Those choices listed may not be available for your car.
Old Mar 15, 2013 | 02:18 AM
pnoyworx's Avatar
10 E63, Sold -07 E63
I have EBC Reds. Works real well for my normal daily use, and very low dust. If you are concerned about dust, stay away from EBC yellow. As for Akebono, they are not made for our car.
07 E63
Thanks.
I found a really good deal on OEM rotors $1600 for front and rear.. i need to find pads.
Old Mar 15, 2013 | 02:22 AM
07 E63
How are they on your rotors?
Old Mar 15, 2013 | 02:49 AM
pnoyworx's Avatar
Hit up Benzworks for rotors, they are two peice and the price will make you smile.
Thanks.
Old Mar 15, 2013 | 02:51 AM
pnoyworx's Avatar
They are fine, mind that I don't do a lot of hard braking or even racing, so my wear is just norm. Whats nice about the reds are they work great even cold. I'm sure you will see more wear with constant hard braking or if you track your car. But for normal use, I am sure it will last you awhile. My reason for getting them was for the low dust, and great all around braking.
