Dreaded p5050 p507 codes after 82MM TB switch
Old Apr 22, 2013 | 11:01 PM
  #51
lowprofile's Avatar
E55
Originally Posted by Roverron
I would love to know many people are driving around with these codes.
And is there anyone with an 82TB with no codes.
I'm looking install one on my car but after seeing this I'm worried.
Never threw a code and I'm certain there are plenty of more people without any issues who never chime in. Don't sweat it.
To be fair, the OP had an issue before he upgraded, and the t/b he tried was not only used but had been modified. In short, he took a chance and it will take a second try to get it sorted.
As well, skratch pointed out that he only used three of the four screw location to mount the throttle body(post #17). I surprised he got it seal up as good as he did.
Old Apr 22, 2013 | 11:13 PM
  #52
berti_00's Avatar
2016 Cls63s AMG
hopefully mine works out fine.. my car right now is as perfect as it gets and i got my plate and gasket all welded on the snout so i will have it installed tihs week and keep you all posted too
Old Apr 22, 2013 | 11:15 PM
  #53
Forrest Gump 9's Avatar
shrimp boat
I never had any code with my 82mm. When I switched to the 90mm I did have the p5050, but Jerry was able to fix that thru his tune. So it's possible to have no code with the bigger tb.
Old Apr 23, 2013 | 09:46 AM
  #54
Roverron's Avatar
ML63
OK thanks to all the responded>>
Old Apr 23, 2013 | 02:15 PM
  #55
bstudey01's Avatar
2003 E55 AMG
Just got back from Speedriven!! Car is fixed Marcin checked everywhere for leaks with brake cleaner and found none, none by the injectors either. Swapped the TB with the new one I picked up and viola!! TPS is right at 2% in drive with foot on the brake. No more codes. He also reset the TCU and it is shifting much better, I was having a hesitation between shifts before. I tried the reset with my foot on the gas but it didn't fix it. Are we sure the Reset works?? Anyways the grinded TB is the culprit. Actually could see daylight if you closed it and looked at the space between the blade and the circumference. I'm thinking it was not put back together correctly after the shaft grind. So to all those out there that are following this thread, keep that in mind. Thanks to all the suggestions as well.
Old Apr 23, 2013 | 02:20 PM
  #56
berti_00's Avatar
2016 Cls63s AMG
wohooo excellent news... congrats homey
Old Apr 23, 2013 | 03:17 PM
  #57
cm60k's Avatar
Glad to hear that Maaaaaaaan,,
party started>>>strawberry cake>>>no nightmare>>>>>warm bed.....
ZAYED,,
Old Apr 23, 2013 | 04:49 PM
  #58
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Same with stock... i have a brand new 82mm TB here (the right one for our cars) and you can look between blade and circumference is around 1mm of space the whole way around....
Old Apr 23, 2013 | 05:48 PM
  #59
bstudey01's Avatar
2003 E55 AMG
Not sure but the 2nd one I got with no shaft grind had much less clearance. Regardless once we swapped the TB the codes did not appear again and tps was right on at 2% so I am positive the TB was the problem
Old Apr 23, 2013 | 06:19 PM
  #60
skratch77's Avatar
2005 E55
Hope its all fixed bro and I don't want to gynx it but I can't tell you how many times I thought I fixed mine a few years ago and the code would sneak up
Old Apr 24, 2013 | 06:27 AM
  #61
Crissus's Avatar
Yeahh, but we both agree that there actually is a visible clearance on the stock unit too, right? That concerns me a little bit now.
I'll do a picture about it later.
Old Apr 30, 2013 | 02:22 PM
  #62
berti_00's Avatar
2016 Cls63s AMG
all put together.... TB Evosport spacers on the surge tanks beltwrap kit and changed the Supercharger OIL
car runs perfect no check engine at all, smoother than before and boyyyy does she sound insane WOW... the throttle response is absolutely noticeable i just tap the gas pedal a little and she just jumps.... cant wait for a re-tune from jerry
you can see my plate on there welded... perfect seal
and trying something different :P my Yellow city lights they look sick fyi
Old Apr 30, 2013 | 03:21 PM
  #63
bstudey01's Avatar
2003 E55 AMG
Looks good!!! My car is now running great and the codes have stayed gone. Also the issue I had prior to TB install is gone. The only thing I can think is we put a hose clamp on the vacuum line that hooks to the back of the TB this time instead of the bracket that was supposed to hold it tight. Maybe I was getting a small leak here and there before.
Old Apr 30, 2013 | 05:07 PM
  #64
SilverStrk's Avatar
05 E55, 07 ML500
Berti looks Clean.. Throttle response is insane isn't it... Also noticed your split cooling.. Good job.. Just wait for the re-tune from Jerry you will be like..
Old Apr 30, 2013 | 05:26 PM
  #65
berti_00's Avatar
2016 Cls63s AMG
i sure do feel a difference and my car sounds insane good... i cant wait to see how it works when jerry tunes it
Old May 11, 2013 | 10:17 AM
  #66
bstudey01's Avatar
2003 E55 AMG
MAP Code!!
Was driving today on the highway cruising around 75mph. Felt a hiccup and noticed that my stft was at +25%, thinking WTF. I ran codes and have a P0105 I think, its manifold absolut pressure/barametric pressure circuit. Car is really struggling to find 14.7. TPS is normal though and this is the only code I can see with my dashdaq, although maybe there are others with star. I can resart the car and it will go back to normal afrs and fuel trims during cruising with very light throttle application. I could actually feel the car hesitate on the highway while it was normal then all of a sudden stft's went to 25% and could tell the ecu was having a hard time finding 14.7. Car idles horribly when in this state, can watch the afr's bounce rich to lean and stft's adjust trying to compensate but ecu can not get it under control. A simple restart brings it back to normal. Anybody know what's going on? Looked at the map on my dashdaq and it shows about 5psi under little to no throttle up to about 25psi at WOT. Looked at all connnections and dont see any vacuum leaks. Looks like I will be going back to Speedriven to see if he can figure it out
Old May 11, 2013 | 03:50 PM
  #67
Denroll's Avatar
'06 E55
What do these do for you? I've never heard about them.
This is exactly the same issue I am having. If you find a solution, please, PLEASE let me know.
Old May 11, 2013 | 05:44 PM
  #68
bstudey01's Avatar
2003 E55 AMG
Was just told may be in the tune and MAP sensor voltage range needs to be increased. I'll let you know when I see Marcin at Speedriven next week
Old May 11, 2013 | 06:36 PM
  #69
berti_00's Avatar
2016 Cls63s AMG
they drop your intake temps down as what they claim
Old May 12, 2013 | 09:40 AM
  #70
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
I love my 82mm tb too it's the shizzle
Old May 12, 2013 | 11:31 AM
  #71
berti_00's Avatar
2016 Cls63s AMG
hahah wait till you get it re tuned than your gona be holly hell......... i feel like my car has gained 100hp lol i know its a mental thing but man it screaaaaaaaaaaam and just wants to goo gooo goo.. the traction triangle flashes all the time lol
Old May 12, 2013 | 11:34 AM
  #72
Manuyc's Avatar
Brah let's do this next week
