My fix to the "gas tank" problem
Old Oct 3, 2013 | 07:44 PM
  #51
Dostovel's Avatar
2008 SL600
Man, this issue really pisses me off. I've read about the "gas tank issues" on here for over the year that I've had it and think the other day I was smelling that gas smell inside my car. It was about 105 degrees here in Phoenix and I'm pretty sure something was amiss... Hasn't happened again though and that was the only time... I really don't want to deal with this
Old Oct 4, 2013 | 11:25 AM
  #52
Critter's Avatar
07 E63 + 07 CLK63CAB
Old Jan 16, 2015 | 02:34 PM
  #53
Max.H's Avatar
E55
Originally Posted by Alps
good fix,
on mine there is no fuel smell, the problem was fuel pump failing to deliver after 5500 rpm, but after opening the cover noticed a pool of fuel on the right side fuel pump and the wiring starting to deform, which is a sign of the pump failing as its drawing too much current.
I opted to replace both pumps which are being fitted next week, also replacing the seals.
Sorry to rehash an old thread. But, how did you know there was a fuel delivery problem? Lean condition after 5500 rpm? Wow that's really bad.
Was it just the melted wires to the fuel pump?
