My fix to the "gas tank" problem
The problem on my car is the sending unit. It's the driver side one. I took it out and filled the unit with JB weld. I tried to cover the whole top of the assembly with JB weld. I also filled the passenger side unit with JB weld too. While I have both of the out I also replace the seal. The old seals are black, the new ones are green. I did this last August and until now I have not have any problem with the gas smell.
The reason I report this now is the last couple days the weather were in the 80' degree range. I checked the pumps and they were bone dry.
JB weld ~ $20
Two new seals ~ $50 from the dealer
And a small worm clamp, that's all I need to fix my problem.
Also if you decide to do this, please run your car down to empty, let the JB weld cure for a day before install (this depend on the thickness), and try not to get any JB weld on any of the plugs/connectors. Good luck.
I put on about 5K miles since the fix. Also I have a brand new MB sending unit if anyone need
I have always thought that some sort of gas-resistant epoxy flooded into those weak areas to reinforce them would be a decent countermeasure.
Keep us informed with how they hold up as the temperatures climb!
How many times have you replaced parts prior to this latest fix?
-G
Thanks,
Thanks,
To my understand, the previous owner replaced the pump once right before he sold me the car. I replaced one more time, so it's on the third one. My car have 106k miles.
The fuel tank has been redesigned 3 times between 2003 and 2006...... As has the PS fuel sender/ pump unit. This is not a simple gasket issue.... We have plenty of folks with "new" gaskets with ongoing leak issues.
-G
I used the old leak unit. I was going to replace with a new one but I figured why not try JB weld, and so far it's worked.
on mine there is no fuel smell, the problem was fuel pump failing to deliver after 5500 rpm, but after opening the cover noticed a pool of fuel on the right side fuel pump and the wiring starting to deform, which is a sign of the pump failing as its drawing too much current.
I opted to replace both pumps which are being fitted next week, also replacing the seals.
Could the whole pump be pulled out? or only when the car has no gas ?
Which product did you use ?
http://www.jbweld.com/products/surfa...ns/automotive/
http://www.jbweld.com/products/surfa...ns/automotive/ so which one ?
