Initial impressions of D2 Coilovers!
My initial impression is that this is probably one of the first things that should be done to our cars. The ride is much more controlled and the car has a feeling of being more poised and connected. The ride is firm but not harsh. I would say it is similar to the ride feel of the e46 M3 I owned with a little less harshness. DISCLAIMER: I like a firm riding car that feels planted to the ground with very little bounce. I have the shocks set at the firmest setting and probably won't ever move them again.
The only items I had to buy other than the coilover set were the rear lower control arms. That's it. No bolts, no bushings, no shims, nothing. I got them used for $150 for the set.
I was just a hair over $900 not counting buying STAR DAS to do the coding. I figure that will be used for several different things so shouldn't be added.
Just google D2 coilovers and see who is giving the best deal at the time. I used a non-supporting vendor so I won't mention the name. They are all within the same price range though ($800-$900).
You can use any w211 rear lowers that had steel suspension. Mine came off of an e500 but they are all the same. Get them used and save a ton of money
I figured the CGW out but I am still trying to figure out exactly what to change in the other areas. At least the car drives fine with the visit shop warning in the IC.
I'm not sure. I just ordered the kit for the e class model # D-ME-11
Just wondering if you still drive this car, I'm bout to do some coilover install and just wondering how they are after a while . Thanks.
