NEED NEW TRANSMISSION
Old 05-14-2013 | 10:36 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Originally Posted by jcjmw
Nice!
Is that pull from the higher stall TQ linear or does it level off versus the stock tq? In other words, is there a sacrifice in high end power or in the higher rpms from the higher stall TQ?
the stall on my upgraded trq converter is pretty much the same as stock... big difference is the internal vains...The pieces inside the upgraded converter are furnace-brazed, which makes the converter stronger and more efficient. Under heavy loads like wot,the fins inside a stock non-furnace-brazed converter will flex. When that happens, the converter loses efficiency and less power is put to the ground, while an upgraded trq converter will put more power down under heavier loads like wot ...and i can def feel a diff now at wot
Old 05-14-2013 | 10:38 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
No way does it cost any peak power. If anything the ten pounds of rotating mass saved will help peak power a little.
Quick Reply: NEED NEW TRANSMISSION
