EC Supercharger pulley failure... :(
Also please add me to the list too. I was in the original first ten people to get the sc pulley. Mine did not break but the pin got loose and I constantly have to re-shim. At one point I think I had up to nine shims. I sent the pulley back to Shardul and he sent me back another unit. With the new unit I didn't even have to use any shim. It's been about a year and all good, but I'll check it tonight.
Period.
Totally agree...these mentioned vendors have gone above and beyond for this community....support them and they will support us..... just my humble opinion.
-Dave
personally, I'm still waiting to see the results of the clutch less pulley that is in development now.
When you work on people's cars that spend between $30-60k, you need to have 100 percent confidence in any parts put on the car. Especially performance related things because everyone knows there is some risk involved.
IF this is true that spring steel was not used in this aftermarket pulley, I would really like to know why. I can partially blame myself for not doing a thorough enough inspection before installing the part, but now I'm going to have to call back a few customers as well as the person that owns the company I work for to tell them the part I installed on their car has a design flaw that was just recently realized. That is strike two with my customer who spent a lot of money on one of the earlier bolted hub 180mm crank pulleys, and it had an issue on its second installation. Eurocharged took their pulley back, and sent me a supercharger pulley free of charge. I do believe the technician that installed the pulley may have been partially to blame, but the new bolt was torqued correctly. I went in to detail with Jerry about what happened and in no way would I have blamed him for not wanting give me a free S/C pulley.
When I put this part on their car I told them it is a completely reliable part that uses a factory bearing, and talked up the part up pretty good. Now we know what has been brought to light in this thread. I'm very frustrated with this.
Knowing what I know now I FIRMLY believe that pinning the crank pulley is an absolute must, as well as using the AMG pulley holder.
Hopefully there is an easy fix for the supercharger pulley issue that is starting to appear.
I work with the warranty end of all of the European companies and you guys would NOT believe some of the things they will not warranty. Brand new Jaguar with a rattle in the headliner. Sounded absolutely horrible. Not covered under warranty. If I had bought that car it would have landed some where in their showroom via their showroom window.
From what I have seen BMW is the best to work with. It seems they care the most about customer satisfaction.
