EC Supercharger pulley failure... :(
Old 05-08-2013, 01:03 AM
  #76
Former Vendor of MBWorld
DavesMeanE's's Avatar
93' 500E, 95' Corolla
Originally Posted by Toadster
+1
my hero!
Oh yeah - We did yours too Todd!
Old 05-08-2013, 05:06 AM
  #77
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
Well on a good note, Jerry appreciated the pictures. They're going to send me a new pulley once I get the old one off.
It'll have to wait until tomorrow since I can't crack the bolt w/o an air tool...Forgot how much of a pain in the *** it was to do.
I used all the shims, per Shardul's instructions. Mileage I'm not sure, but I've only had the pulley for less than 6 months, and I don't drive it much. Driving hard? Probably once ever 1-2 weeks. I take care of my car. It was spaced properly. So I don't really know. Maybe it was just a bad pulley. Bought it in November.
Old 05-08-2013, 07:39 AM
  #78
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Originally Posted by layzie12g
... as well as using the AMG pulley holder.
You dont happen to have the part number for the AMG pulley holder?
Old 05-08-2013, 07:45 AM
  #79
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Not the MB one but basically the same-
http://www.ebay.com/itm/Mercedes-Flywheel-Crankshaft-Lock-Engine-Repair-Tool-/121076167414?pt=Motors_Automotive_Tools&hash=item1c30b3b2f6&vxp=mtr
Old 05-08-2013, 09:04 AM
  #80
1badassbenz's Avatar
Mercedes
I haven't installed mine yet I bought mine in February. Anything I should look or check for or just install it and see how it works? Don't want to use the word bad batch but is there a difference between earlier ones and later ones built or is this something we will all need to deal with at one point.
Old 05-08-2013, 09:12 AM
  #81
desant89's Avatar
2007 S550
I am seeing a lot of questions asking about a "bad batch" Did we in any way confirm that it was a bad batch, or is it a problem with the strap that was, and is still used on all of them?
Just want to make sure I make mine right. I just got mine less than 2 weeks ago. If there is a such thing as an updated pulley, I would think I have it. Question is, who confirmed there ever was an update?
Old 05-08-2013, 09:20 AM
  #82
Tech-Tune's Avatar
^ Good point.
It would be nice if Shardul or a Eurocharged rep would chime in to clarify.
EDIT: Just got in touch with Shardul... The new pulleys have a different spring.
Old 05-08-2013, 09:40 AM
  #83
pimpjuice's Avatar
2003 E55 AMG
Hmmm...mine is still on the shelf. Should I "update" the straps? I don't have a press or a drill press...can someone hook a broke brothah up lol
Old 05-08-2013, 09:54 AM
  #84
novae500's Avatar
W211
Originally Posted by Tech-Tune
^ Good point.
I picked up mine in Nov 2012. Checked the car last night and so far no cracks/breaks. When were the new pulleys sent out?
Old 05-08-2013, 10:01 AM
  #85
pimpjuice's Avatar
2003 E55 AMG
How do we know which is a new pulley? I wonder if I can ship mine back to swap for a new one before I install it ???
Old 05-08-2013, 10:13 AM
  #86
Tech-Tune's Avatar
I would confirm prior to installing it. Better to play it safe.
Old 05-08-2013, 12:03 PM
  #87
Kreuzfeuer's Avatar
SRT-6
M112 guy reporting in... Looks like mine hasn't failed yet, but I'm not sure how much time I have.
This is an early batch EC 65mm pulley on the M112 3.2 Kompressor.
Note the stress crack near the rivet.
Also worth noting, the back of the pulley is now making permanent contact with the supercharger clutch. Clutch can be spun by hand, but not freely. Pulley has already been adjusted twice to alleviate this, each time adding shims to allow a gap. So, the springs are clearly letting loose, as I keep losing the gap over time. I'll contact Jake/Jerry privately, no reason to believe that they won't support the return as they've offered stellar service to me and my Crossfire brethren in the past.
All the best,
Attached Thumbnails EC Supercharger pulley failure... :(-ec-pulley-failure.jpg
Old 05-08-2013, 12:55 PM
  #88
Denroll's Avatar
'06 E55
^You've got the telltale reddish-brown dust like me. I'll check mine when I get home in a week or so.
In somewhat related news, Shardul says the tuning for the new clutchless upper pulley has been sorted out.
Old 05-08-2013, 12:57 PM
  #89
Tech-Tune's Avatar
Eurocharged is sending me a revised replacement...
Its a comforting feeling to deal with a tuner that stands behind their product (or a product they endorse)
Old 05-08-2013, 01:31 PM
  #90
Forrest Gump 9's Avatar
shrimp boat
All the best,
You need to send your back. Your pulley is having the same problem with my first, the pin is backing out. The more shim you add will only make it worst. You're at the borderline of that thing spinning apart.
As for my second unit, just checked it last night everything seems to be fine. No crack, no dust.
Old 05-08-2013, 02:01 PM
  #91
Kreuzfeuer's Avatar
SRT-6
I've been battling the red dust here and there for a year... We revised the gap and the dust ended... briefly. As you've noticed, now it's back. Is that dust from the back of the pulley, or the clutch (or both?)? Not sure which material is softer. NBD if it's the pulley, I just don't want the clutch to be at risk.
Agreed.
Totally NOT what I wanted to hear, but what I suspected. I'll drive it gingerly the next few days until I can swap out with a backup. No telling how long that one spring has been cracked.
Old 05-08-2013, 02:44 PM
  #92
Karlson's Avatar
06 E55
got same question, got mine from the neighbor that he got 2 months ago, so is there visual difference of older and newer version of the pulley?
Old 05-08-2013, 03:17 PM
  #93
Baronet1's Avatar
'05 E55, '12 C63
yes, read the thread.
Post #82. newer version has different spring.
Old 05-08-2013, 03:21 PM
  #94
desant89's Avatar
2007 S550
Does that mean it looks physically different? I am going to check mine too. Hopefully we get a pic of the old vs new or something if there is a visible difference.
Old 05-08-2013, 03:22 PM
  #95
pimpjuice's Avatar
2003 E55 AMG
that still doesn't say what the visual difference is. Can someone post a side by side of the old v/s new? I'm interested as well... did I ever mention smart asses are full ratards?
Old 05-08-2013, 03:24 PM
  #96
ricky s's Avatar
o6 e55K AMG
Anyone know when the 'newer spring' was produced?
Old 05-08-2013, 03:27 PM
  #97
Baronet1's Avatar
'05 E55, '12 C63
This isn't rocket science folks.
Call up EC/Jerry and find out when the new ones with new springs were sent out and verify against when you purchased it.
I'd venture a guess that EC/Jerry will chime in here soon. But in the meantime, why not call and find out? I'm surprised nobody has called yet.
Old 05-08-2013, 03:32 PM
  #98
pimpjuice's Avatar
2003 E55 AMG
I have contacted Shardul since I purchased mine directly from him. But it would be nice to see a side by side of the new and older ones posted together. Now go read the thread and see that several people have contacted Jerry/EC...the jury is still out at this point
Old 05-08-2013, 03:38 PM
  #99
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Wish I would have taken more pics of mine now. All I have is this one of the front before installing it and the tape is half covering it. Can't really tell if looks different or not. I got mine first thing in January.
Old 05-08-2013, 03:40 PM
  #100
Baronet1's Avatar
'05 E55, '12 C63
Exactly my point. it's simple, now people have to wait to hear back.
Quick Reply: EC Supercharger pulley failure... :(
