Macht schnell E55 project
Rating: Thread Rating: 5 votes, 5.00 average.
Old May 11, 2013 | 02:53 PM
3BNick's Avatar
2006 E55
I had those same marks from the oil pump drive chain when I replaced my bad pump. We definitely need a stronger chain tensioner spring for that bad boy. Tear down is looking good. I'm impressed how fresh these motors look after racking up so many miles. I know mine looked just as good as yours when I opened it up at 71k.
Old May 11, 2013 | 04:56 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Great job, Sir Boost. At some point you need to post pics of your Camaro.
Old May 11, 2013 | 05:04 PM
RAWAMG's Avatar
SL55 AMG EC Stage 5 Beast / ESS S/C E92 M3
Man I am so glad you posted up!!!! I have been wanting to tell the world what you have been up to haha! Looking good Chris... looking damn good brotha
Old May 11, 2013 | 05:36 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Looks good, thanks for taking the time to document and show pictures.
Old May 11, 2013 | 05:43 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Looks like it is coming along nicely. Great job and thanks for sharing.
Aaron
Old May 12, 2013 | 07:27 AM
MindBend's Avatar
'05 E55
Nice to see. After all, it's just another motor!.
Keep up the nice work.
Old May 12, 2013 | 06:26 PM
  #32
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Thanks all! I've been mapping all this out for a while, it's fun to actually put it all to use! I've got some cool adaptive engineered parts that I'll be using that will help to build 55k engines to the next level without taking the financial uppercut to the jaw that is known as "one-off parts"
Originally Posted by Forrest Gump 9
No kidding. How's about offering a rebuild service
I could, but aren't you in Texas? Brooke and Shardul are much closer and have more experience with this engine than I do.
Originally Posted by urbamworm
All I know is these bigger blower cars have my mind swirling again. I had lost interest since it took so long to come out then bought some 20" wheels/tires for dang near $4k and figured I would be better off just having what I have power wise and keeping my money since that is a good chunk of change to drop on the blower.
If I happen to meet up with Chris on my next visit home end of July and get a ride or do a comparison run it might just have me sold. I freaking love speed and my car is the fastest car I have ever been in and it isn't really fast in my opinion, at least not consistently. I want to be fast all the time and on the next level. Make it happen Chris, make it happen!
After seeing the difference in traps from Gadget's car though on cooled down runs to hot lap runs I say these setups need a killer chiller still like the stock supercharger. Might need to get one of those too.
I personally like a meth/water setup over a killer chiller because the killer chiller can't keep up with the heat. It just cools your reservoir down and then your IATs keep climbing until you rest for a while, producing inconsistent results. I like an IC system that is suited to do what it needs to do. As in I have this much heat to remove, what will it take to remove it. Weistec did the best they could do with the space they had to work in, but it's still a compromise because the valley between the heads isn't big enough to accommodate a large core, and the blower will hit the hood if you space it up any higher to gain room that way.
The Weistec intercooler core as you can see isn't much biggest than the stock one, but its design looks similar to the high performance Garrett cores I use when building an A2A intercooler so volume/volume it will transfer more heat. Also it's a single pass from the top which will eliminate the restriction of the front to back flow of the stocker. In a perfect world, this blower would have a 40mm or so spacer on it and double the intercooler core like the ford mod motors do.
Here's a comparison. Ford modular V8 lower manifold
Weistec Mercedes
Old May 12, 2013 | 06:47 PM
  #33
Here's the fresh crank back from CRE racing engines. Dave told me he had to recalibrate his balancer because he couldn't remember the last time a V8 ran such a featheresque 1546 bobweight. A light polish on the mains and a moderate polish on the rods to allow a few ten-thousandths more oil clearance.
Look at the end counterweights and you can see the holes drilled into it to lighten the rotating mass. For those not familiar with engine internals, when the rods and pistons become heavier or lighter than stock, the weights of the crankshaft counterweights must be adjusted accordingly or severe vibration and bearing damage will occurr. Since the new SLR pistons are signifigantly lighter than stock anchors, the crank gets drilled. If the new parts were heavier, large portions of the steel counterweight are drilled out and round slugs of "Mallory" metal are pressed in which have much more weight per a given volume.
Old May 12, 2013 | 11:23 PM
  #34
GT-ER's Avatar
2005 E55 AMG
The black pieces in your oil strainer are not silicone, they are the rubber surroundings from the intermediate sprocket in the timing chain. It's normal for it to get detached from the sprocket and get stuck on the oil strainer.
The wear on the timing cover from the oil pump chain is also normal.
Old May 13, 2013 | 01:14 AM
  #35
sergs99m3's Avatar
M3, E55, SL55
Correct
Old May 13, 2013 | 01:58 AM
  #36
Ah I see. I just looked at the donor engine I used for the MID block build and see the timing chain idler coating. That engine had 1/3 the miles the one from the car does.
Don't say that the wear on the cover though is normal. We could say " it's a design flaw that ails most M113 engines" but in no IC engine on earth is it acceptable for a steel chain to beat the aluminum cover while the engine idles, spewing metal shavings into the oil. I understand hat the metal grinding is minimal and the filter element will remove most of it from oil circulation but that's a problem that needs some aftermarket love.
If for no other reason just to cure that embarrassing clacking sound. My neighbor has an 06SL500 w 45k on it and his sounds the same way.
Old May 13, 2013 | 02:34 AM
  #37
Forrest Gump 9's Avatar
shrimp boat
No sir, I wish I was in Texas. I'm in Columbus, Ohio.
Old May 13, 2013 | 08:25 AM
  #38
GT-ER's Avatar
2005 E55 AMG
So true. By normal I mean they all do it at some point apparently, but you are correct...it's not OKAY by any means.
Old May 13, 2013 | 10:28 AM
  #39
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
THIS
SH*T
RIGHT
HERE
When I pull my 55 into a drive thru, and the person that works there leans over and goes "your car doesn't sound right", it just KILLS me, and it happens A LOT. "Yeah, nice Benz buddy. Sounds like it's about to die". I've heard it all, and I've only owned this thing for a month. So am what I'm seeing from this, there is no upgraded tensioner assembly (like the all steel ones I use in my Ford builds), or some sort of shim we could work into the mix, or is the only option to literally shave down the timing cover in that area, because damnit I'm the type of guy that will yank an engine to fix something like this. I HATE IT.
Back on topic though, GREAT write up so far man. I wouldn't mind swinging down to lend a hand or take a look sometime since I'm right up the road in Gainesville. Keep up the great progress, and please keep the pics coming. I'm reeeeeeal familiar with 5.4 Supercharged Ford Mod motors, but these 5.4 SC Benz setups are a whole different animal.
Keep it rolling man.
Old May 13, 2013 | 04:02 PM
  #40
ajm55's Avatar
2006 E55 AMG
Awesome write up sir! Good luck with the rest of the build. Should be a monster
Old May 13, 2013 | 05:05 PM
  #41
lowprofile's Avatar
E55
Nice project. Thanks for sharing the pics.
Are you going with the included ring pack? Iirc, the pistons are Mahle?
Old May 13, 2013 | 07:41 PM
  #42
blackbenzz's Avatar
haters crazy
Badass BuIld!!!
Old May 13, 2013 | 08:00 PM
  #43
E55Greasemonkey's Avatar
This place is a joke.
Thanks for posting and looking forward to seeing you run at Orlando Speedworld!!
Old May 16, 2013 | 05:08 PM
  #44
tooFATtoDRIVE's Avatar
'03 E55 Estate
Excellent read. Subscribed!
Old May 16, 2013 | 05:10 PM
  #45
Thanks! I'll have another update later tonight.
Old May 16, 2013 | 05:11 PM
  #46
Thank you and Yes , using the rings from Mahle.
Old May 16, 2013 | 06:05 PM
  #47
MAN55LE's Avatar
04 E55 AMG
Originally Posted by berti_00
respect my friend... and lots of it
it looks amazing and posting pics and DIY is takes it to huge new level for me and probably some others. I get to learn new things, and stand up gentlemen like yourself, keep me from experiencing the learning curve to it's entirety. You have all my respect!
Old May 20, 2013 | 08:00 PM
  #48
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Weistec Mercedes
Can`t wait to see you put a 3.3 whipple on.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 20, 2013 | 08:15 PM
  #49
Whose got one of those? Sounds big?
Old May 20, 2013 | 08:16 PM
  #50
Btw lotta good it did redlabeling in pistons... Main caps bolts gotta come from Germany ....
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
