Transmission Oil Leak
2004 E55 AMG
So i replaced the infamous pilot bushing which was slowly leaking on my car with mb part number A 2035400253 at the local dealer as well as had the transmission oil changed (dropped the pan , filter and oil) about 10 days ago.
Driving home on a warm day last thursday go do downshift, car downshifts no problem, look in my rear view mirror to see a ton of smoke. I pull over and notice transmission oil leaking on to the exhaust). Anyway car is back at the dealer but wondering if anyone has had a similar experience.
PLATINUM SPONSOR
They improved the seal, so you should be good for life after the change.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
