what size pulley is this???
Old May 21, 2013 | 11:25 AM
thumper823's Avatar
04 E55
measure's 7.25 inches in diameter, edge to edge. which equals 184.15mm. there are no stampings on it other than factory stamps on accessory pulley.
Old May 21, 2013 | 12:15 PM
Roverron's Avatar
ML63
7.25 inches = around 180 millimeters
Old May 21, 2013 | 03:21 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
i think a 7.25in is accually 185mm.
Old May 21, 2013 | 03:33 PM
black06c230's Avatar
mgLipGD
That things looks a little rough.
Old May 21, 2013 | 05:48 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
First, do not measure from the outer ring, as the lip may be higher than the ribs the belt runs on. My guess is that is an ASP 178 to 180 mm and it looks like it was on a 4x4.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 22, 2013 | 10:10 AM
thumper823's Avatar
04 E55
thanks guys i ended up using a string to get the circumference then divided by pie. came to 178.2 so theres my answer. damn never thought id need to use pie after high school! lol
Old May 22, 2013 | 10:35 AM
mgLipGD
Awesome
Old May 22, 2013 | 10:50 AM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
I believe that's a 178mm boat anchor. I wouldn't put that thing on a lawnmower.
Old May 22, 2013 | 11:32 AM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
I like pie!
Old May 22, 2013 | 03:32 PM
Robert AMG's Avatar
Cls63 & C32
Do you want to sell it?
