finally changed my supercharger oil
Old 06-01-2013, 08:25 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Originally Posted by Max.H
Your supercharger clutch is probably saturated with oil hence the slippage... Over filling is not a good thing if you got seals in there. You might want to go through it once over to make sure you didn't rupture any seals or it could just leak again.
No seal is going to rupture, the oil leaks out of the SC pulley bolt if you overfill.
Old 06-01-2013, 09:42 PM
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Sooo how much should be filled without overflowing? Roughly half the can? 3/4?
Old 06-01-2013, 09:44 PM
PACougar's Avatar
Until it drips out of the fill hole, it's just like filling a diff.
Old 06-01-2013, 09:46 PM
These overflowing horror stories have me a bit worried though lol.
Old 06-01-2013, 09:50 PM
hank55's Avatar
e55 amg, gmc acadia, wrx, integra
just slow fill and it wont over flow by much. stretched the cars leg a bit, down shifted and did a quick 60-110. car feels great, even in this 108 az weather
Posted from Mbworld.org App for Android
Old 06-02-2013, 02:39 PM
Max.H's Avatar
E55
Ohh good to know PACougar! Makes sense since its such a high rpm unit.
Old 07-25-2013, 12:48 PM
  #32
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
Got my Jet Oil II. Having a helluva time finding a plastic syringe with a tube. Went by the farm and feed store down the street, as well as tractor supply. Nothing.
Old 07-25-2013, 01:38 PM
  #33
Try autozone. Last time I went there they had a syringe kit with the plastic tube.
Old 07-25-2013, 01:57 PM
  #34
typhoon43's Avatar
Location: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Just ordered mine. Car has 75K on her with a 180 lower spinning the snot out of the blower. Time to show her some love.
Old 07-25-2013, 03:53 PM
  #35
jnash's Avatar
2017 S63
There is a thread somewhere that I was reading the other day that explains exactly how much SC jet oil to fill. It is NOT up to the fill-hole according to the MB procedure that I read on that thread, its a lot less. That's why we all observe that the fluid appears to be low. If I find it I'll link to it.
Old 07-25-2013, 04:00 PM
  #36
Baronet1's Avatar
'05 E55, '12 C63
Can someone post up a link for what oil to get (OEM) and how much?
I didn't read the thread, thanks guys.
Old 07-25-2013, 04:59 PM
  #37
taurran's Avatar
Just tried it, and they didn't have it. (surprise surprise)
I think the problem I'm having is I live in Florida. Everyone and everything in this state sucks *****.
Old 07-25-2013, 05:37 PM
  #38
Denroll's Avatar
'06 E55
I found one at Wal Mart.
Old 07-25-2013, 06:04 PM
  #39
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Get a 20cc plastic syringe at any CVS or Walgreens. Plastic tubing at Home Depot or Lowes.
Old 07-25-2013, 06:42 PM
  #40
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I got one at Pepboys in FL. Near the gear oil.
Old 07-25-2013, 10:53 PM
  #41
taurran's Avatar
Thanks for the suggestions, guys. I'll try those places tomorrow to see if I can find anything.
No clue what area of Walmart something like that would be in, though.
Old 07-25-2013, 11:46 PM
  #42
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
interval is 100,000 miles on this. I am going to do mine tomorrow!
Old 07-27-2013, 09:53 PM
  #43
taurran's Avatar
Just finished mine.
- I finally found a syringe in Walmart, in the motorcycle oil section, and used it. It's for mixing 2-stroke oil or something. However, the tube that came with it was too big. I ended up going next door to lowes and buying some 1/4" clear tube, which fit exactly inside the diameter of the larger tube. Sealed it off with some teflon tape and it sucked well, but barely squeezed in the hole. If your tube is curved, you have to angle it down and left in order to get suction.
- I only got about 90ml out of the car with the tube.
- I realized the supercharger wasn't exactly level, so I threw a jack under the rear diff and lifted the rear of the car to level it off. Then, I put jet oil in it until it came out of the hole. Put the tube back in and sucked a slight amount out (barely any) to level it off, and then sealed it back up with the bolt and teflon tape.
- The old oil literally does smell like a barn yard. It reminded me of the smell of old cow ****. Yuck.
- Having a towel stuffed in under the bolt hole was the best suggestion of all. I wouldn't recommend trying it without it (like the guy who lost the bolt).
- I sealed the towel, syringe, tube, and measuring cup into a ziploc bag and put it away for next time. I'll probably wait a month or two and do this again, just to make sure all of the old dingy oil is out of the mixture.
Thanks for all the suggestions folks!
Old 07-28-2013, 06:29 PM
  #44
AgSilver's Avatar
Just finished mine.
Never lift your car by the differential! You will destroy the heat sink.
Old 07-28-2013, 06:42 PM
  #45
PACougar's Avatar
You just need a piece of ply or similar between the jack and the heat sink, it'll be fine.
Old 07-28-2013, 11:15 PM
  #46
taurran's Avatar
Yep. It's fine.
Old 07-29-2013, 06:49 AM
  #47
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
So how is a overfill possible when the SC is still in the car?
Up to level of the hole and that should be it, right?
How did you guys manage it to overfill?
Old 07-29-2013, 02:35 PM
  #48
AgSilver's Avatar
Yep. It's fine.
OK fellas, I believe you, but it seemed pretty scary to me.
Quick Reply: finally changed my supercharger oil
