Graphic throttle body info
I think we are hitting load v/s throttle threasholds that are not in the tune. Think about this. If the throttle is supposed to be 18% at a given load range and we are achieving that load at 12 % throttle- the ecu may not have that duty cycle built into the map and available to tell the injectors to open enough.
The engine runs perfectly most of the time however it does run erratically after a long run at extremely light throttle and then trying to re-accelerate. When this occurs the engine runs extremely Lean to the point it will backfire buck and pop. At times when pulling up to a red light at idle it will do the same thing.
At first I thought this was a result of the 550 injectors causing a rich overall mixture and the computer compensating for it. So i reinstalled the stock injectors and has Jerry from eurocharged send me a new tune. It displayed the exact same drivability issues.
I then contacted other industry pros to help out. One led me down the path of the throttle body and gave me a good argument. Since NO 112-113 engine ever came with an 82mm TB, the calibration just isn't there. I think this is very well the case.
I took apart a stock TB and an 82 to measure a few things. Here is what i found!
The gear set and stepper motors are identical in every way. The sweepers are slightly different in the resistance value. I am going to try a set of resistors to get an identical setup to stock to see if that is the problem. Ill let u guys know.
I had a new 82 mm Merc TB from Modern horsepower, My shop had to open and change wires around, Then was all good I have ec tune, But factory inj. Hope helps.I can call them in am and see if they did anything else to make it work if you like?
. Just took the car out to find some hills and bamm!! Actually was only doing about 65 going up the hill and felt the slight hiccup stft's maxed. I knew it was too good to be true. Question for others that are having this exact issue, do you guys also get a hiccup once and a while at lower speeds upon light throttle application. I do notice it sometimes around town at about 30 when I press lightly on the gas. No, it is not the s/c engaging and it feels almost identical to the one on the highway but it doesn't cause the stfts to go out of whack or throw the code. Just thinking out loud. Anybody swap the cap from a 74 to theirs yet? I may try this, seems like it shouldn't be too difficult
I have had new map sensor, new wiring to map sensor the TB & bypass TB, 3 TB's, 2 different intakes & pretty much every "fix" that people have suggested.
I have had a couple of times when it has happened at low speeds (less than 40) but 90% of the time it is around 80mph cruising and then slight uphill.
If I gun it or accelerate no problem, I have taken the car to 180's several times at full WOT and no issue and can drive for hundreds of miles at less than 70 without issue.
If I gun it or accelerate now problem, I have taken the car to 180's several times at full WOT and no issue and can drive for hundreds of miles at less than 70 without issue.
Interestingly it happens less with the EC map than the previous 2
Not tried swapping the caps
However, I doubt the throttle body per say is the issue. None the less, I tested my stock and 82mm t/b today. Stock was .973 ohm and the 82mm was 1.009.
No issues with mine. Oetune if that becomes relevant.
Anyone know of another forced induction speed density car that uses the Bosch ME? Everyone I can think of uses a MAF system.
