Graphic throttle body info
Come to a stop or slow role
After a few seconds the tb starts to close
Idle drops and car will cut out or to try correct itself the car surges up to 1500rpms
At that point codes are thrown
These symptons are only under vacume and I have 1000cc inj, e85, bip tune, 82mm tb, 3000 stall, 3.06 gears with clk55 tcu etc.........
There are lambda tables that appear to have settings/adjustments the whole way across the load/RPM range. Does it even matter at WOT/high-load because ECU goes open-loop.
The stock O2-sensors are not widedband, nor are they fast enough to matter, IMHO.
Any insights appreciated.
yes the car goes into open loop under WOT and has a set a/f ratio in Open loop. every fuel injection car pretty much does open loop upon WOT.. Closed loop is for cruising, emissions, MPG unless it has a wide- band closed loop option.. Only stand alones at this time
I completely Agree. I had a Kleemann tune with 80mm TB tried to pass emissions and car was pig rich at idle. well after datalogging, I find out my Kleemann tune was staying in open loop (25 sec)after decel from 2500rpm to idle and dumping fuel.. then would correct itself once it went back into closed loop..
I then installed with no other changes a Eurocharged tune. the open loop to closed loop transition changed from (25sec) with the kleemann tune to (5sec) with eurocharged tune and was able to pass ca emission 2 weeks ago with just rear cats.
I have figured out...that when the car acts up, the ecu has seen an implausable figure from the map sensor. It goes into a "save the catalytiic converter" mode and plugs in a pre-determined value that would work for the stock set up. But modded, runs lean as ****. Until you restart
Do you know where to get a 80mm tb CLS ecu??? I assume they are alot of money from MB. Maybe somebody has one from a junk car
A1121534479
A1131532579
A1131533979
A1131536079
Not sure which I have but I'm going to check in the morning and will post it. Maybe others with the issue can post theirs and we will see if we all have the same ECU. Then if some with the 82's that are working flawlessly have different part #'ed ECUs we may be on to something there.
I would think the tuners should be able to do this too, as well as any dealer, probably done with star??
If you have star, Go to ME-SFI, control unit adaptations, learning processes, default initialization.
Once you start it, you should hear your fan go on real quick. This clears ALL of the adaptations and will let the car reset correctly.
Thanks brotha. Promised myself that I won't mod it until the E55 is running like a swiss watch. Its really been hard to keep the wrenches off of it since they respond so well to mods. But lets just say I'm in the accumulation stage of the mods. I think my garage is good for an easy 250hp bump on that thing
