'06 E55 Oil Level Sensor DIY
Old Jun 4, 2013 | 08:09 PM
EBe55amg's Avatar
2006 E55 AMG
Anyone know of a prior post explaining how to change the oil level sensor? For the 2006 E55. Or could someone explain.
Thank You!
Old Jun 4, 2013 | 08:32 PM
E55Greasemonkey's Avatar
This place is a joke.
The sensor is mounted externally on the bottom of the pan. Remove engine underpanel. Drain the oil, take out 3 screws and replace it. Refill oil. Done.
Old Jun 4, 2013 | 08:34 PM
EBe55amg's Avatar
2006 E55 AMG
Thank you! Do you think I will need a lift?
Old Jun 4, 2013 | 10:21 PM
Roverron's Avatar
ML63
I did it with jacks and a jack stand for safety
Old Jun 4, 2013 | 10:27 PM
MAN55LE's Avatar
04 E55 AMG
and found out the mm increment for the high and low oil! thanks again, post up if you want the measurement for the upper and lower on the stick 135mm low and 169 mm high
Old Jun 6, 2013 | 05:41 AM
MindBend's Avatar
'05 E55
It's VERY easy to do. Some have speculated you have to drop the oil pan, etc. which simply isn't so.
As GreaseMoney has stated, it's a 5 minute deal once you're under the car. I think the part even has the little rubber gasket already pre-installed.
Old Oct 25, 2014 | 08:44 AM
cij911's Avatar
one car at a time
I need to replace mine, but will try to do so without replacing the oil (as it was changed recently)...Hopefully I can swap the part w/o too much of a mess ...
Old Oct 25, 2014 | 01:36 PM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Just did mine during routine oil change. Took an extra 5 minutes, no more "Oil Sensor Malfunction" BS message on the dash :-)
Old Oct 25, 2014 | 01:53 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
You will have a big mess if you do not drain the oil first. It will come rushing out of the sensor port when the sensor is removed.It will be easier to drain the oil first.
