Getting start lowered tomorrow, how low?
I'm having a few things done on the car tomorrow and figured it'll be a good time to have it star lowered. My problem is I'm not sure how much to have it lowered. I'm on stock wheels/tires for now but if I like the way it rides once lowered I'd be looking to get some 19's. however I'm concerned as to the tide quality and tire wear. I know our cars have no camber adjustment, what would it run to buy a camber kit? How low should i go? normally i'd opt for the lowest possible but... Thanks
I never used star.. i really cant say how low it really is. When i was exploring the idea of using the start method, i remember being told that I would only be able to go about 1/2 inch. Tons of guys have used star.. i would just search the forum for threads. there are a ton of way to lower this car some are sketchier then others. i ended up buying the Renntech module.
I'm lowered roughly 1" from stock. Current fender lip height is 25.5" at all 4 corners.
At that setting, the alignment shop could only get me to a minimum of -2.5* of camber front & rear. That's not terrible, but I'm sure it's going to cost me some inner tire wear. There isn't much adjustment at all with the factory suspension bits, so as you lower the car you are going to get lots of negative camber.
-G
-G
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Lower the car in comfort to the maximum allowed values. Then when you put it in Sport2 it will go lower
