How much cash you put into your ride to date?
#35
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,399 Likes
2012 CLS63
#36
How much ?
Well , like one person wrote you don't want your wife to read this thread ,, I love what the car has become , but don't love what it has cost me . Let's say in reality and everyone knows what I'm going to say TOO MUCH MONEY . But to play with the big boys , you have to pay like a big boy .
#40
Well if your next to a car and you both nail it and you pull away it doesn't matter ,and you don't really care. but if the other car is out front I believe you know to the penny what you spent ,along with some curse words starting with mother and then your day is ruined.
#42
Someone needs to close this thread.
If I keep seeing it pop up I will eventually add it all up.
Then I would never be able to look my dear sweet wife in the eyes again
#43
20K Car
4K Warranty
1800 evotech/tune
2600 HRE's
900 Tires
400 rail
300 injectors
3000 MBH Headers/xpipe
400 Trunk tank
300 Heat Exchanger
1200 Evosport Rotors
350 Poterfields
1500 Meisterschaft's
800 Exterior Carbon Fiber
1600 Motor Carbon fiber
500 Euro Command
800 BWK/SC pulley
500 Tcu Tune
Forgot the Quaiffe $1300!!
2500+ Install Labor/maintenance
=![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
OMG what is wrong with me!!
4K Warranty
1800 evotech/tune
2600 HRE's
900 Tires
400 rail
300 injectors
400 Trunk tank
300 Heat Exchanger
350 Poterfields
500 Euro Command
800 BWK/SC pulley
500 Tcu Tune
#44
20K Car
4K Warranty
1800 evotech/tune
2600 HRE's
900 Tires
400 rail
300 injectors
400 Trunk tank
300 Heat Exchanger
350 Poterfields
500 Euro Command
800 BWK/SC pulley
500 Tcu Tune
4K Warranty
1800 evotech/tune
2600 HRE's
900 Tires
400 rail
300 injectors
400 Trunk tank
300 Heat Exchanger
350 Poterfields
500 Euro Command
800 BWK/SC pulley
500 Tcu Tune
#45
300$ --- front tires
750$ --- OE tune
250$ --- secondary cat delete
200$ --- rear peds and sensor .. (oem)
300$ --- PDR on rear door
150$ --- oil change
10$ --- 2x xenon bulb
100$ --- used ballast (oem)
250$ --- mags for slicks 17in
all this in one month
750$ --- OE tune
150$ --- oil change
#47
I don't have any real problem with my car just do regular stuff....
Both battery $200
Rear Tires $400 include installed
Water pump $400
Engine\ tranny oil change $1300 for the lat 4 years
Spark plugs $200
Coolant flash $100
Valve gasket seal $240
Engine mount $1k (stupid dealer)
My next thing is to do the coilover conversion before my airmatic goes bad and that will cost around $3K. Better handling and dont have to worry the airmatic anymore.
#48
2006 E55
In the last 7 months and 7,000 miles of ownership, I think around $2,500 spent.
All of it has been catching up on maintenance that was neglected before I purchased that I feel was about par for a car with 71,000 miles on the clock and a couple of performance/reliability goodies along the way. I also saved a butt load by being a master tech and doing all my own work (read: stunts) and buying parts at cost or less depending where the deals were.
So far, I've replaced all motor mounts, oil pump, valve cover gaskets, pano roof motor, rear tires, both front inner tie rods, front camber bolts, rear main seal, trans filter and gasket with fluid change, both belts, a weak starter, aux battery, voltage regulator (didn't need it yet, but the brushes were worn down pretty good), and a radiator flush. As for upgrades, just a PLM HE, CM30, secondary cat and resonator delete with x-pipe, lowering module, and some lighting upgrades.
Hah! just did some quick math...I have spent almost $2,000 in just gas for the last 7 months and I don't even drive it every day.
#49
Can you tell me what wheels you picked up for your slicks? I'm looking to get some cheapos for the track.
#50
I've owned it for four months and I'm at $19,954.77, including the car ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I need rear tires, but only because KDW2s don't hook for ****
