Highest HP E55
Old Jun 25, 2013 | 11:45 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Originally Posted by 2319
I just thought it would make an interesting thread. There are a ton of variables on both. I don't think either is definitive on a cars true power by itself. I have seen both manipulated.
Are you saying you've seen track times manipulated for the better?
Old Jun 26, 2013 | 12:03 AM
2319's Avatar
2005 E55
I am saying that I have seen drivers that can manipulate a car into going faster than it should. See Curt Brown, John Shepherd, Marco Passante for example.
Old Jun 26, 2013 | 12:31 AM
e55amgrocket's Avatar
Dirt Scooters
Make cars go faster than they should? That's what I do
Old Jun 26, 2013 | 12:35 AM
PACougar's Avatar
What you mean is you've seen most drivers go slower than a car can go and a few that get them to go as fast as they can. Unless you've seen people use magic to make a car break some laws of physics.
Old Jun 26, 2013 | 12:46 AM
UNvisible's Avatar
#81 MX5 Cup, M52 E30 325i, 2500HD Duramax 500rwhp
"make cars go faster than they should" Is dis nga serious?
Old Jun 26, 2013 | 03:47 AM
SavMan's Avatar
2004 E55K AMG Wagon
Spot on, I witnessed a modified CL55 hit consistent times all day, the owner then had his friend run the car in the knock out stages. The friend just happened to be the UK street nationals champion and the car went consistently 0.3 secs faster until getting knocked out in the semi finals.
Old Jun 26, 2013 | 09:15 AM
  #32
2319's Avatar
2005 E55
What I am saying is that 10 out of 10 people could not make Curt's cars go as quick and as fast as he did. Some people sell their soul to the devil it seems. I have seen more cars under perform because the driver can't drive too. A dyno takes driving out of the equation. But a dyno has many factors that can be manipulated. So IMO, neither by itself can be the end all say all of how a car performs. Both can yield a pretty good basis to go from.
Back to the topic, who else has dyno numbers we can look at that are over 5xx whp and above?
Old Jun 26, 2013 | 09:37 AM
  #33
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Whomever spraaaaaaays the most , will have the highest HP/TQ on the forum and there are a bunch that use the drug I`m still drug free for now
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 26, 2013 | 09:57 AM
  #34
Toadster's Avatar
2005 E55 AMG
quickie survey to answer that...
https://mbworld.org/forums/w211-amg/...-you-have.html
Old Jun 26, 2013 | 10:50 AM
  #35
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Originally Posted by BBBSS
Fastest MPH would be better than elapsed time. Tires, launch, any suspension mods and weight etc etc will make a car with the same HP have faster ET's. MPH is a better determining factor for raw power although its far from perfect as well.
Obviously with your 1/4mi time slip you would have your MPH there which is used to determine what kind of power your car actually makes
Old Jun 26, 2013 | 01:55 PM
  #36
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Yep, just saying I think if you want to play who has more power you should compare MPH more than ET when comparing E55's vs E55's. I feel this would be a more effective way of comparing power. There are still variables here, but less then with comparing ET's.
Old Jun 26, 2013 | 02:36 PM
  #37
RedBullJnky's Avatar
you to Hate
Here. This is in S FL 100* heat and humidity over a year ago.
Q16 and meth
Old Jun 26, 2013 | 06:20 PM
  #38
2319's Avatar
2005 E55
Nice dyno sheet. Are you running straight meth? Where did you put your nozzle?
Old Jun 26, 2013 | 07:05 PM
  #39
you to Hate
50% M1 and 50% distilled water. I posted in your thread about the nozzles.they are after the IAT sensor since I'm not tuned for meth.
Old Jun 26, 2013 | 10:00 PM
  #40
Max.H's Avatar
E55
If they are not all using the same dyno, settings, and conditions who really cares? They are all going to be different. You should be looking at who has the fastest 1/4mi time as that will truly tell how much power someone is making IMO.
Aaron
That same rule you mentioned for the dyno applies to the track. Even if not more so as well.
I think it's a fair question, Im interested in knowing as well. We can pick apart everything. But, often times that takes the fun out of an interesting topic.
So, who's got the most power?? So, far redbulljunky is showing some serious power 550whp
Old Jun 29, 2013 | 10:53 PM
  #41
Max.H's Avatar
E55
Guess Redbulljunky has the highest hp E55. Congrats! :-P
Old Jun 30, 2013 | 09:19 PM
  #42
you to Hate
Hahaha! Thank you, thank you, thank you.......
Wait till I finish this build.
Old Jun 30, 2013 | 10:51 PM
  #43
2319's Avatar
2005 E55
Who is doing your build red bull?
Old Jul 1, 2013 | 07:44 AM
  #44
MindBend's Avatar
'05 E55
RedBull,
Nice dyno slip! (no BS there!).
I noticed you spray meth after the IAT sensor. I understand that you're not tuning for it, which is a great plan that matches my own.
However, have you watched/logged the timing to see if you can gain some with the meth advantage? AFR?
Old Jul 1, 2013 | 02:24 PM
  #45
ArmoE55's Avatar
2006 E55
I thought skratch77 made the most power ...
Oh never mind, that was the SLR's dyno sheet that he posted claiming it was his car's ... oops.
Old Jul 1, 2013 | 02:31 PM
  #46
MindBend's Avatar
'05 E55
If more would spend time driving instead of concentrating on the measure of their "things", this would be a happier place.
If it's just about dyno-numbers, you could build just an engine, put it on an engine-dyno and save all of the other hassles and expense.
More street war-stories, please!?
Old Jul 1, 2013 | 06:31 PM
  #47
you to Hate
Rage-Tek (owner is a friend of mine) is the only person that touches my car. And Jerry is the only person to tune my car.
Originally Posted by MindBend
RedBull,
Plenty to gain if I tuned for it, but I never really wanted it on my car. It was really the only way to go, since it is so freakin hot down here.
Get some vids of the Wiestec car killing anything.
Old Jul 1, 2013 | 08:01 PM
  #48
MindBend's Avatar
'05 E55
Yeah...the meth works great. I think I'm gonna put it on my wife's grocery-getter too!
No videos yet. Pickins' mighty slim lately.
Old Jul 2, 2013 | 08:46 PM
  #49
blackbenzz's Avatar
haters crazy
He's the ricer hoopty club enforcer
Old Jul 2, 2013 | 09:02 PM
  #50
you to Hate
