new KLEEMANN alloy boost pulley!
Old Jun 28, 2013 | 08:10 AM
GregMB's Avatar
Originally Posted by DonnieD
I produced and tested three versions of the non damped pulleys...look on a stock pulley, there will be a frequency printed on it...dont you think the unlimited engineering budget of Mercedes Benz will have a reason for this? The frequency will offset the negative vibration produced by by the engine. The damper will absorb and help cancel it....
This is interesting information, but if this is true then a modified factory pulley (with damper) isnt a perfect solution either. Seems like when you add a larger ring to a stock pulley you are moving its tuned frequency away from the factory spec.... probably to a lower value. (Hz)
For a 168mm pulley perhaps the change is minimal, but for a 195mm pulley you are adding literally POUNDS of extra mass. Whatever tuning was done with the factory damper can't possibly be worth much once the pulley is modified so radically.
Just thinking out loud.
-G
Old Jun 28, 2013 | 08:18 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
i will never install a crank pulley again.
Old Jun 28, 2013 | 09:01 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by Cory @ Kleemann
Can you elaborate? EC has been selling non-dampened pulleys for quite some time without failures and from what I can tell, they seem to be very popular.
Hey Cory,
I just wanted to clarify, all of our crank pulleys are internally dampened and always have been! (we have a spring system etc)
Congrats on the product!!
Old Jun 28, 2013 | 04:24 PM
cij911's Avatar
one car at a time
Non-dampened crank pulleys are not a wise option IMHO....Good luck
Old Jun 29, 2013 | 12:15 AM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
I've assembled and later disassemble several small block fords that were ran with various centrifugal supercharges. Each example was ran with solid mounted super charger drive hubs,one was clogged. A couple of these had solid tensioners that allowed for excessive belt tension. All of the engines I built were externally balanced versions (damper was an intregal part of the balance of the rotating assembly). I never found any excessive wear and tear on the main/thrust bearings. I currently run a solid mounted overdrive crank pulley on my Lightning and have experienced no issues with it for over a year and several thousand of miles. I know I am not comparing apples to apples here, but the mechanics are basically the same. I don't see this being an issue with a quality designed and properly installed part.
Old Jun 29, 2013 | 12:19 AM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
I'm confused, you're saying you ran an external damper on all of your engines? If that's the case then you're really not comparing apples to apples because this pulley isn't dampened.
Old Jun 29, 2013 | 12:27 AM
  #32
marcmaddox's Avatar
Yes, the later SBF engine (302, 5.0L,5.8L) are externally balanced. The hub/damper is counter weighted as is the flex plate/flywheel. You can internally balance them, but it is very expensive to do so. Irregardless, the point is- All these engines had solid supercharger drives attached to them and no harm was ever encountered. The same should hold true with these engines also. Oh, and I stated that I knew I wasn't comparing apples to apples. The principle of the subject is similar and the results should be similar as well.
Old Jun 29, 2013 | 12:44 AM
  #33
PACougar's Avatar
So would you run a non-dampened crank pulley on one of your externally balanced engines? I'm not sure why you're bringing up the SC drive, it has nothing to do with running a non-dampened crank pulley.
Old Jun 29, 2013 | 12:52 AM
  #34
marcmaddox's Avatar
Never mind. Your missing the point completely. Perhaps it's my explanation. I'll just bow out and let you guys make your own decisions.
Old Jun 29, 2013 | 12:55 AM
  #35
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
How much are the other brand that keeps the factory dampner? I wouldn't want to remove the dampner from a high performance motor. Especially when you start pushing it past originally designed limits.
Old Jun 29, 2013 | 02:01 AM
  #36
black06c230's Avatar
mgLipGD
Marcmaddox: Irregardless
That is not a real word.
http://www.urbandictionary.com/defin...m=irregardless
http://grammar.quickanddirtytips.com/irregardless.aspx
Carry on now
Old Jun 29, 2013 | 08:30 AM
  #37
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I have a very high regard for Kleemann products. However, in this case, I suggest considering lightweight rotors which will reduce rotating mass by close to 40 lbs. There is a significant improvement in performance, handling, and braking. Additionally you do not have to be concerned with engine damage or reliability.
I have been running an ASP 168 for 40k+ miles.
If you're building an all-out racer, then "you buy your tickets and take your chances."
Old Jun 29, 2013 | 08:46 AM
  #38
marcmaddox's Avatar
Since I was called out on my grammar I'll add this...The damper itself is still a engine harmonic damper. The supercharger pulley is simply solidly attached to it, in this case (and the point of my examples) instead of being attached with a shock absorbing coupler. The only thing the dampened coupler does is reduce the shock of the super charger engagement. The engine harmonic damper (the part the supercharger pulley is attached to) is not affected.
Feel free to critique my grammar if it makes you feel better.
Old Jun 29, 2013 | 09:00 AM
  #39
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Maybe I'm still a little wobbly from last night ( I def am) but I'm having trouble deciphering that post. Are you saying that the dampening function of the stock balancer/pulley is to reduce supercharger engagement shock?
Old Jun 29, 2013 | 09:02 AM
  #40
marcmaddox's Avatar
Basically, yes.
Old Jun 29, 2013 | 09:20 AM
  #41
marcmaddox's Avatar
The only issue I see with this type of pulley is more pronounced belt slippage when the supercharger clutch engages. This will be even pronounced if a smaller than stock super charger pulley is used (less belt contact with pulley).
Old Jun 29, 2013 | 09:29 AM
  #42
Who told you that ?
Basically, yes.
Old Jun 29, 2013 | 09:30 AM
  #43
marcmaddox's Avatar
Experience told me that.
Old Jun 29, 2013 | 09:50 AM
  #44
PACougar's Avatar
You need to experience more.
Old Jun 29, 2013 | 09:55 AM
  #45
Either you're really far off in outer space, or I'm just not in synch with what you're thinking.
Old Jun 29, 2013 | 09:57 AM
  #46
marcmaddox's Avatar
Question
lol. Ok, enlighten me. How about some actual technical information. I won't expect a lot, as smart-*** comments and conjecture are about all I see on this site.
Old Jun 29, 2013 | 10:01 AM
  #47
PACougar's Avatar
How about it's there to dampen vibrations through the rotating assembly. Don't get me wrong the SC engagement is certainly a cause for concern when it comes to that. By all means test your theory out, others have ran non-dampened pulleys on these cars and it didn't turn out to well for them. At the end of the day if you want to find out the hard way go for it.
Old Jun 29, 2013 | 10:12 AM
  #48
marcmaddox's Avatar
If failures occurred, I suspect it is due to the build quality of the pulley, or poor installation. The simple fact I am trying to convey is- A solid mount between the damper and the super charger will NOT cause engine damage. A poorly designed and/or built piece certainly can.
Old Jun 29, 2013 | 10:23 AM
  #49
PACougar's Avatar
I know you're going to think I'm a *******, but I'm not trying to be. You don't think the dampener is there to remove any other vibrations except ones caused by the engagement of the SC? Also, even if you believe that, how much experience do you have with these motors, it appears you're trying to make one hell of a extrapolation from your experience. Let me ask you this why do all MB have have dampened crank pulleys, most don't have clutch engaged SC's?
Old Jun 29, 2013 | 10:40 AM
  #50
marcmaddox's Avatar
Ok, I think I understand our misunderstanding. I am talking about the way the super charger pulley is attached to the damper. The stock unit (pulley) is attaced to the damper with a coupler that allows for a small amount of rotation, seperate from the damper itself. A shock absorber coupling, so to speak. The pulley they are offering has no such coupling. It is attached directly to the damper. The engine harmonic dampening capabilities are not compromised if the damper is properly designed. My point: a solid mounted super charger (to the damper) in of itself, will NOT cause engine damage.
