My unique trunk tank install
Old Jun 27, 2013 | 12:20 PM
thumper823's Avatar
04 E55
Well i think its unique Been putting off the trunk tank install for months now because i was afraid of losing my spare wheel. But i finally came to a conclusion and the system seems to work flawlessly. (only been 2 days but im keeping a close eye on everything.
completed
2 hook tabs that notch into brackets bolted to the bottom of the package shelf
mounted, used another small bracket on the front and use a wing nut to quickly drop and re-mount the tank.
two main hose's and also the drain hose
hose routing thru right rear wheel well
through but not touching any of the suspension components or axle shaft, even when the suspension is compressed there is plenty of room.
heading up front
the tank mounts strong and sturdy, can be dropped down to pack with ice within 10 seconds and reinstall just as fast.
Old Jun 27, 2013 | 12:28 PM
berti_00's Avatar
2016 Cls63s AMG
How do you drop it if you wana dump ice lol
Old Jun 27, 2013 | 12:33 PM
thumper823's Avatar
04 E55
did you read?? lol. it has a hook system in the rear and a wing nut in the front that holds it up in front and also holds the hooks in place.
all i do to drop it down is remove the wingnut and slide it toward me a inch. and it drops right down. i left just enough slack in the wiring and hoses to allow plenty of room to set it down and fill.
Old Jun 27, 2013 | 12:41 PM
pragmatic1's Avatar
e 55
I'm confused. Why would you do such a thing? Not being a smartA#$, just curious.
Old Jun 27, 2013 | 12:57 PM
thumper823's Avatar
04 E55
well i seem to get atleast 2 flat tires a year driving here in michigan.. so the last thing i wanted was to remove the spare for the belly pan trunk tank mount. i could have mounted it in the belly pan and kept the spare on top of the carpet panel but then i wouldnt have room for my golf clubs
now i have a trunk tank and spare in factory location and plenty of room for golf clubs lol
Old Jun 27, 2013 | 01:44 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
From hat I can tell, your mount is pretty ingenious in order to keep the spare.
Old Jun 27, 2013 | 01:49 PM
Denroll's Avatar
'06 E55
I like this approach. How much room is under the bottom of the tank? Can I still fit 3 small prostitutes back there?
Old Jun 27, 2013 | 01:50 PM
HeissRod's Avatar
Depends.....do you plan on deflating them first?
Old Jun 27, 2013 | 01:52 PM
Denroll's Avatar
'06 E55
Yeah, typically they aren't alive at this point in my game.
Old Jun 27, 2013 | 01:57 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
why didn't you run the hose underneath the panels?
Old Jun 27, 2013 | 02:13 PM
thumper823's Avatar
04 E55
once the spare is in, there isnt much room in there to run hose's. plus i would need to hack out a large section of the spare cover and would look a little more tacky imo.
i like this a lot because the tank is up high and all the hose's route right alone the side panel. all of the spare/jack/tools ect are easily accessable just as they are stock.
Old Jun 27, 2013 | 02:14 PM
thumper823's Avatar
04 E55
could fit three but one of them would have to be severely under aged.
Old Jun 27, 2013 | 02:26 PM
HeissRod's Avatar
Then a wood chipper + ziplocs guarantee fitment.
Old Jun 27, 2013 | 02:41 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I'd rather have it in the spare well, but that works great if you need to keep the spare. Nice job!
Old Jun 27, 2013 | 02:46 PM
WoodyBang's Avatar
05 E55
What tank did you use? Pump? How much did they run?
SilverStrk's Avatar
05 E55, 07 ML500
Dennis your real name is Dexter isn't it
Old Jun 27, 2013 | 02:53 PM
No but if you say Denroll backwards slowly it sounds like LLORNED which means nothing but confuses the hoes long enough to chloroform rag her and wrap her in duct tape
Old Jun 27, 2013 | 02:54 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I am scared to not have a spare tire. I drive the car long distances and already have had a need for a spare with only driving the car like 10,000 miles in the last 2 years!
That is why I didn't do a trunk tank and made my under the hood tank that holds about 1.5 gallons. Because the spare is a life saver so can't put a tank down there and then a bulky tank in the trunk takes up room for putting stuff back there!
Was thankful for my spare while traveling and this happened.
While this setup is interesting, I think it would still be an issue when trying to stuff the trunk with stuff though since it would be handing down only giving a small amount of room under it for small stuff.
Old Jun 27, 2013 | 03:02 PM
berti_00's Avatar
2016 Cls63s AMG
^^^yahh man these spares are a must have.. my car has no space for it as it never came with one but i got a new one of a cls63 it sits in my trunk and doesnt even bother me so even if i do a trunk tank i have room under there
Old Jun 27, 2013 | 03:24 PM
thumper823's Avatar
04 E55
its a DADS tank. I think shardul knows the guy and can get a price. i may be wrong though.
the pump is a Rule 2000 bilge, mine was a used tank and came with the pump but not sure if they sell seperate.
Im also running a Meziere in the front
Old Jun 27, 2013 | 09:50 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I like your mounting method.
Old Jun 28, 2013 | 12:49 PM
thumper823's Avatar
04 E55
thanks!!!
Old Jun 28, 2013 | 02:05 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
looks good nice fab work on your brackets. I have a question about the second pump is it in the tank or is it mounted outside of the tank? Also how did you do the wiring to the 2nd pump? You don't have to get in to much detail but just something simple if you don't mind?
Old Jun 28, 2013 | 02:55 PM
AMG E Power's Avatar
E55 amg
Awesome job !
Old Jun 28, 2013 | 03:06 PM
thumper823's Avatar
04 E55
its a Rule 200 bilge pump that mounts right inside of the tank.
trunk fuse i tied into. i ended up running the wire from this fuse and along the top package shelf hidden. this fuse has power in key position two.
here is the front fuse i tied into at the fuse box for the meziere front pump. both have power at key position 2
