What's the verdict on the smaller SC pulley?
Old Jul 8, 2013 | 05:55 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
83mm
Old Jul 8, 2013 | 08:00 PM
blackbenzz's Avatar
haters crazy
Originally Posted by Toadster
the s/c pulley is excellent - quicker spool-up, seems to be much safer method of power versus the crank pulley option - love mine!
I thought we went through this last time. I guess you haven't learned. These cars are not turbocharged. You cannot get "quicker spool-up"
Crank pulleys have failed, especially from a certain manufacturer that was sold by some of the same people. These supercharger pulleys have failed as well. Hopefully the new version works better
Old Jul 8, 2013 | 08:08 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
A smaller diameter pulley wouldn't spin the rotors up quicker?
Old Jul 8, 2013 | 08:10 PM
blackbenzz's Avatar
haters crazy
It spins it faster (more rpm) to make more boost. Same concept as a bigger crank pulley. Twinscrew SC is instant boost. It is mechanically driven
Old Jul 8, 2013 | 08:15 PM
HeissRod's Avatar
Doh.
Old Jul 8, 2013 | 11:28 PM
Toadster's Avatar
2005 E55 AMG
spool spin potatoe potato
Old Jul 9, 2013 | 01:52 AM
  #32
TheVazha's Avatar
W213 E63
Thanks for the conversation guys. Please complete the equation using =,<, or >
ASSUMING TUNE AND COOLING TO ACCOMPANY THE PULLEY:
Smaller SC ___ 168MM Pulley
Smaller SC ___ 172MM Pulley
Smaller SC ___ 175MM Pulley
Smaller SC ___ 180MM Pulley
Smaller SC ___ Flux Capacitor
Old Jul 9, 2013 | 10:06 AM
  #33
GregMB's Avatar
Ask and you shall receive.....
Yellow = Stock size pulley
Green = Smaller S/C pulley
Blue = Larger Aftermarket Crank Pulley
Ultimately, it all boils down to the pulley ratio that you achieve by combining the upper and lower pulley. A smaller ratio produces less boost....a larger ratio produces MORE boost. This is shown by the supercharger RPMs in the last column of the table. It doesn't matter how you get there (larger crank pulley & stock SC pulley, or stock crank pulley & smaller SC pulley)... if the ratios are the same, the power increase will be the same.
In this table, you can see that the smaller SC pulley gives almost identical performance as a typical 168mm crank pulley swap (1.86 vs 1.87 ratio) and if you already had a 168mm crank pulley, swapping in the smaller SC pulley would be virtually identical to running a 180mm lower pulley with a stock SC pulley. (2.00 vs 2.02 ratio)
(NOTE: This analysis ignores any additional benefits from reducing rotational mass on either the crank or SC pulley)
Extra Credit Question:
As everyone knows, the flux capacitor is a 1.21 Gigawatt device. Converting from watts to HP (746 watts/HP) yields a horsepower increase of roughly 1.62 million additional horsepower.... that's crank HP, not wheel HP.
-G
Old Jul 9, 2013 | 10:50 AM
  #34
rockthemullet's Avatar
2005 Mercedes E55 AMG
-G
Argh, I guess I should have refreshed the page... I was doing the exact same thing you just did in excel. The 168mm is 86.67% over and the SC pulley is 85.54% over, so the exact equivalent crank pulley would be a 166.99mm (like Greg said, pretty damn close).
Keep in mind that theoretical boost is linear but real boost is not, showing a rate of diminishing returns due to pumping losses. Not only are you battling the heat with higher boost but system restriction as well.
Old Jul 9, 2013 | 11:16 AM
  #35
Toadster's Avatar
2005 E55 AMG
-G
I love that!
Old Jul 9, 2013 | 11:59 AM
  #36
AMG E Power's Avatar
E55 amg
Ok doing the math says upper pulley is about the same as a 168 crank pulley then why has no one ever posted gains of 30-40WHP with just a upper pulley added by itself ?
U can go and Search ppl with 168 pulley and headers also trap 122-123mph
Never seen that with the sc pulley and headers.
I just would like some real world facts. If there the same I should Technically be able to go to the same dyno under the same weather conditions and make 30 wheel horsepower at Minimum by adding it to my current mods ? Right ?
Old Jul 9, 2013 | 01:14 PM
  #37
GregMB's Avatar
You are just as likely to gain 30HP by adding a 168 pulley or a smaller SC pulley.... Numerically, the solutions are IDENTICAL. It truly doesn't matter which side you modify to get to a ~1.86:1 pulley ratio.
The question of whether you actually WILL hit +30HP or not is going to depend on whether you re-tune the ECU for a pulley swap, and if your IATs are under control with the additional boost.
Adding a smaller SC pulley is one of the most dirt-cheap ways to add power there is..... so it may appeal more to guys who don't want to spend money on cooling mods or dyno-tuning. Obviously, if the rest of the car isn't being set up properly to take advantage of the extra boost you are going to come up short on power gains.
-G
Old Jul 9, 2013 | 01:49 PM
  #38
E55 amg
Well as u can see in my sig I have plenty of cooling and my tune has boost maps in place already so if what ur saying is correct then I should gain that much power. Still Skeptical being the only dyno proof I've seen only got five wheel horsepower. Guess I will just have to get it and dyno myself.
Old Jul 9, 2013 | 01:52 PM
  #39
ArmoE55's Avatar
2006 E55
Who?
Old Jul 9, 2013 | 02:41 PM
  #40
Toadster's Avatar
2005 E55 AMG
-G
I question the "identical" statement here - one is a crank pulley which implies more weight and more rotational mass to spin throughout the S/C belt path
the S/C pulley is lighter and smaller rotating mass, so it puts less wear/tear on the motor overall...
not sure the parasitic losses compared to each pulley method but I'd guess that the S/C pulley is less
Old Jul 9, 2013 | 02:47 PM
  #41
novae500's Avatar
W211
What are the rwhp #s a bone stock E55 on a dynojet ?
168mm pulley= 42whp
MBH LTH = 45whp
Smaller s/c = ?? whp
Bone stock E55 = 400 ??
Total = 496rwhp is what i got on a dynojet
Old Jul 9, 2013 | 02:51 PM
  #42
FinanceMike's Avatar
CLS55
168mm pulley= 42whp
MBH LTH = 45whp
100% stock with a CM30 pump
411whp and 454wtq
ECU Tune
444whp and 481wtq
SC Pulley - Box Tune
451whp and 502wtq
Kleeman headers - Box Tune
478whp and 515wtq
Custom dyno tune (These were peak. We chose 487whp and 521wtq as the safest tune)
491whp and 525wtq
Old Jul 9, 2013 | 02:53 PM
  #43
Toadster's Avatar
2005 E55 AMG
168mm pulley= 42whp
MBH LTH = 45whp
adding the S/C pulley onto the 168mm already will skew the numbers...
as well as dynoing with TTM scoops
Old Jul 9, 2013 | 02:55 PM
  #44
ArmoE55's Avatar
2006 E55
My 06 dyno'd 408rwhp/461rwtq two weeks ago... bone stock (stock IC pump, too) to the tires. 85', mild humidity.
Old Jul 9, 2013 | 03:16 PM
  #45
viren.89's Avatar
2004 E55 AMG
So it's less than 18% loss eh, that's pretty good.
469*0.18= 84.42
469-84.42 = 384.58
and you got 408
What dyno was it on ? cuz I think that matters a lot
Old Jul 9, 2013 | 03:18 PM
  #46
ArmoE55's Avatar
2006 E55
Mine was a Dynojet.
I was very happy with the numbers given it's the summer months, but there are some on the board in the 41x range and some in the 42x range... stock.
Old Jul 9, 2013 | 03:22 PM
  #47
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
For what it is worth, I made 499whp uncorrected on a dyno local to me on a cool engine run with a 180 pulley. I went back to a stock crank pulley and put a smaller supercharger pulley on and went back to the same dyno (this was not the same time frame though and about 15* cooler). My first run on the dyno with the supercharger pulley in place and a "box tune" for it made 446whp (the car was running way to rich, 10:1). The tune was adjusted and the car was reflashed about 20 minutes later and did 476whp on the next run and then immediately after (like 1 minute later) did one more run and did 480whp uncorrected. So there was a difference of a peak 19whp between the 2 different setups taking in to account the weather difference. My other mods are Kleemann headers with aftermarket mufflers and 80mm throttle body as well as cooling stuff.
The bigger difference was the torque where with the 180 pulley it made around 550tq and the supercharger pulley setup made 497tq.
With the big pulley it was less consistent though and would lose a lot of power on consecutive runs where it was much closer with the smaller supercharger pulley setup. On my first run on the dyno with the 180 pulley the car had ran for 2 or 3 minutes on the dyno before they did a pull because they didn't shut it off while they were adjusting a strap. The first run it did 470whp then they did a run shortly after and it went down to 450whp. After letting the car sit for about 30 minutes to cool off is when it did 499whp uncorrected 509 STD correction.
So a supercharger pulley is certainly going to give you power as long as the tune isn't running to rich.
Old Jul 9, 2013 | 03:28 PM
  #48
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Kauve trapped 120 with a EC tune and smaller sc pulley. So add headers and your right there at 123 or higher.
Old Jul 9, 2013 | 03:35 PM
  #49
HeissRod's Avatar
442hp/480tq here back in April with only an 010 pump & FTP HE in 60° weather
Old Jul 9, 2013 | 03:36 PM
  #50
GregMB's Avatar
Toad,
You're arguing the "mice nuts" portion of this equation... maybe 2 or 3HP would be my guess.
That would be like dyno'ing a car that just got 4 new lightweight brake rotors to see what the HP difference was.....you might be able to show a difference on the dyno, but most people don't care that much.
The real benefit (IMHO) is never having to risk touching that lower crank pulley and bolt... the SC pulley swap is a lot simpler and less risky. From what I've seen the only failures were attributed to excessive clutch gaps. If you get that right during the installation, you're probably golden forever.
-G
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
