M113 (55 Series) Engine Block
Old 07-13-2013, 07:48 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Originally Posted by blackbenzz
I don't understand. You said you know they are different. Please enlighten us with your vast knowledge. Are they different because of the part numbers stamped on them?
And since you want to keep going off topic. How many failed pulleys have you sold and how many have you paid to repair the damages on???
How much do you get in kick backs from MIR for setting / advertising track rental on all forums
Old 07-13-2013, 07:49 PM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Good & important point Ahmad,
Some of the stamps #s, are related to the factory production line of the product it self, even if we got a different #s,
this is NOT mean we have a different parts....!!
I believe all M113 has the same identical basic Block,
maybe the difference between them is brackets or something can be made in the M113 block, that can be capable
fitment to the M113K....!!
ZAYED,,
Old 07-13-2013, 07:51 PM
superstar's Avatar
03 R230 SL55 / 94 W124 E500
Originally Posted by shardul
Yes sir, I will send you a PM, latest by tomorrow, with all the part numbers.
PM received. Thanks for the help!
Old 07-13-2013, 07:54 PM
blackbenzz's Avatar
haters crazy
Originally Posted by superstar
So the cylinder crankcase from M113 NA can be bolted to M113K engine? I am asking this because I was planning to get a M113 NA block ”dust cheap” and beef it up with forged internals and bolt it in M113K motor.
I want to wait until Shardul posts the difference he's so certain about and posted publicly before I tell you the truth. I can picture him frantically searching google and part number right now But I think based on my previous post you can get your answer.
ZAYED,,
Exactly Zayed
Old 07-13-2013, 07:55 PM
blackbenzz's Avatar
haters crazy
I don't do track rentals for money. We all know what you're here for
So what's the difference?
Old 07-13-2013, 08:00 PM
shardul's Avatar
I can picture Ahmad just sitting in front of the computer waiting anxiously for my reply.
I have help to OP that is all that matters
Old 07-13-2013, 08:02 PM
  #32
blackbenzz's Avatar
haters crazy
There is this new device called a cell phone. Some of which even have internet access and can receive emails when you're subscribed to a thread. Pretty cool huh? Are you actually sitting behind a computer waiting for my responses?? And this is pretty fun for me
Old 07-13-2013, 08:07 PM
  #33
cm60k's Avatar
Exactly Zayed
Thankss for confirmation...
ZAYED,,
Old 07-13-2013, 08:16 PM
  #34
RedBullJnky's Avatar
you to Hate
Old 07-13-2013, 08:35 PM
  #35
Max.H's Avatar
E55
Oil squirters to start would probably not be found in the NA m113.
Whats the big secret about the differences that need to said privately?
Old 07-13-2013, 08:36 PM
  #36
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I don't know if this helps, this is the block that comes in the supercharged cars. It's definitely a different block, but I don't know what's different.
Old 07-13-2013, 08:46 PM
  #37
blackbenzz's Avatar
haters crazy
Initially I thought the same thing about the oil squirters but when I had my CLK55 engine apart it did indeed have oil squirters
Exactly, why so secretive?
Anything bolted to a 55k block can be bolted to a NA 55 block. Heads, timing cover, trans, oil pan, etc etc. I've done it. There may be differences but it won't prevent you from interchanging parts. I should have kept my old blocks. Your part number doesn't match what was posted for the 55k. You must have a knockoff version lol jk
Old 07-13-2013, 08:47 PM
  #38
moosejaw's Avatar
none
wow this thread has gone way off topic.
A pissing contest at its finest. For once there isnt a pig or moose involved.
Old 07-13-2013, 09:03 PM
  #39
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
Originally Posted by RedBullJnky
+ a gazillion!
I don't about you guys but I am entertained...and on top of it all...the OP is getting answers! Love it!
Old 07-13-2013, 11:56 PM
  #40
superstar's Avatar
No big secret was given here privately! Shardul has confirmed the part numbers for the blocks as he promised in his early post, in addition he explained the differences between the two blocks lays in the material and coating of the sleeves beside the squirters.
Now the question is, can the NA Block “Just the block” with M113K internals bolted to M113K motor, handle the boost of the blower? Maybe, Blackbenzz has the answer, since he interchanged parts between the two motors.
Old 07-14-2013, 01:02 AM
  #41
blackbenzz's Avatar
haters crazy
Different Material???? And They Both Have Aluminum Blocks, Alusil Cylinder Walls, And Squirters. Great Source Of Information He Is. Did You Notice The 55K Part Number On The Block Pictured Does Not Match? His Block Must Be Different Too Huh?
Yes. I'm Running A Weistec SC On Stock Na Motor. 55K Rods And Pistons Fit In Na Block. Its Been Done Several Times.
Old 07-14-2013, 01:30 AM
  #42
cm60k's Avatar
The N/A M113 & M113K sharing the same pistons standard size which is (97.25mm), with maybe different coat,
i hope im not wrong....?!?!
ZAYED,,
Old 07-14-2013, 02:21 AM
  #43
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
I too was impressed to learn that the NA M113 had oil squirters just like it's bigger brother the 55K. Just goes to show how much abuse the 55 NA was built to take!
The following is AMG's description of their NA M113 creation.
To reach such high-performance characteristics, the high-displacement, lightweight V8 unit, which only weights around 368 lb, features several inventions from racing sports. Thus, the engine is equipped with racing-type forged aluminum pistons for better compression of the air-gasoline mix in the combustion chamber. To always ensure optimum cylinder charging and thus an optimal combustion, an established feature from motor sports, a variable intake manifold, as well as a twin-tract intake system was installed in the engine. Since all these measures led to higher motor temperatures, the cooling of the engine and especially the pistons was redesigned as well. The specially developed oil spray nozzles reliably cool the pistons, even under extreme conditions and full load. In the end, the technicians at Mercedes-AMG increased the engine's performance enormously, contributing to the dynamics and driving pleasure of the four high-end Mercedes-Benz models.
Old 07-14-2013, 02:25 AM
  #44
shardul's Avatar
deleted
ChrisVannoy (05-03-2021)
Old 07-14-2013, 03:07 AM
  #45
you to Hate
Wasn't me!
I picked him up at the airport and partied with him all weekend, then dropped him off at the airport.
But I do know a lot of people down here, and I know names.
Old 07-14-2013, 07:29 AM
  #46
Administrator
Rock's Avatar
Drives Slowly
Thread cleaned.
Old 07-14-2013, 07:43 AM
  #47
MindBend's Avatar
'05 E55
RedBull, this is the best assembling of smilies I've seen! ROFLMAO!
(now hitting the DO NOT SUBSCRIBE)
Old 07-14-2013, 08:42 AM
  #48
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
I know the crank shaft is different, just don't know how it differs.
I assume the profile is different but I'm just guessing.
Old 07-14-2013, 09:49 AM
  #49
superstar's Avatar
That’s great!
Did you sleeve the motor? I would sleeve it , if I was running high boost .
It is always interesting to see how much these engines can take with stock internals before they start to give up.
Old 07-14-2013, 10:29 AM
  #50
schino's Avatar
2005 E55, 11 second truck, ducati streetfighter 1098
I've got nothing really to contribute besides that I'm in the manufacturing business of machining parts. We have parts that we make which have different part numbers for later assembly while all machining is exactly the same. A prime example that jumps in my head is an oil pump for a jet engine which everything is identical except one o ring in assembly but it is two entirely different part numbers from the start.
Quick Reply: M113 (55 Series) Engine Block
