Fast question EC TB 82
Old Jul 26, 2013 | 03:29 PM
macko's Avatar
e55 2005
What do I do with the new open hole?
The old body is different
Old Jul 26, 2013 | 03:37 PM
Hulk's Avatar
A Merc
U gotta tap it
Old Jul 26, 2013 | 03:41 PM
macko's Avatar
e55 2005
I do not understand. It's impossible to translate the plug.
Old Jul 26, 2013 | 03:46 PM
Hulk's Avatar
A Merc
That plug will not come off the stock plenum
Try tapping it with silicone and a plug
Old Jul 26, 2013 | 03:58 PM
macko's Avatar
e55 2005
Is it possible to make there mini airfilter, or plug it to vacuum? How do U think? In totally, U think is it verry important hole, or doesn't have special metter?
Old Jul 26, 2013 | 04:06 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Since it is going on a W211 E55 that port is not used. You can put a rubber cap and a screw clamp on it and close it.
Old Jul 26, 2013 | 04:08 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Fill it with aluminum!
Old Jul 26, 2013 | 06:59 PM
cm60k's Avatar
I thought that hole for the vacuum brake booster.....?!?!
ZAYED,,
Old Jul 26, 2013 | 07:19 PM
E55Greasemonkey's Avatar
This place is a joke.
That's basically a fitting with a black block-off plug inserted, just use a heater bypass cap and hose clamp from the local auto parts store.
Old Jul 26, 2013 | 07:52 PM
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by E55Greasemonkey
That's basically a fitting with a black block-off plug inserted. You can buy both pieces new from the dealership, or just use a heater bypass cap and hose clamp from the local auto parts store.
thats what i did... it clipped right on
Old Jul 27, 2013 | 03:36 AM
macko's Avatar
e55 2005
and here how to solve the problem?
Old Jul 27, 2013 | 03:56 AM
macko's Avatar
e55 2005
What do you think about that?
Old Jul 27, 2013 | 10:35 AM
That type of hose may get soft with heat. Better to use black automotive hose, for fuel or coolant.
Old Jul 27, 2013 | 12:20 PM
berti_00's Avatar
2016 Cls63s AMG
So thats not an oem TB?
Old Jul 27, 2013 | 12:56 PM
Roverron's Avatar
ML63
Yea I was told the E/C 82mm kit was a OEM TB and now I'm thinking its not.
I'm going to check part number to confirm.
I'm not 100% sure but what does it hurt to check?
I have read in a post that the caps can be swapped so I'll be a little upset if I find out I was misled thinking this was an OEM part.
Old Jul 27, 2013 | 06:16 PM
Does that 82 not have the port on the bottom for the pcv hose to attach?
Old Jul 27, 2013 | 06:29 PM
berti_00's Avatar
2016 Cls63s AMG
Yahh if its OEM it should have the hole for the pvc
macko's Avatar
e55 2005
Don`t have the port on the bottom, throttle body compensates for pressure, my question goes in the direction of questions,
Has anyone tried to connect the vacuum hose just like the picture at hand had only the power cord that fits perfectly matched.
P.S. Sorry for my bad english, I`m newbie
Old Jul 27, 2013 | 07:18 PM
Roverron's Avatar
ML63
I plugged mine as well
Old Jul 27, 2013 | 07:24 PM
Roverron's Avatar
ML63
check for leaks
Old Jul 28, 2013 | 06:13 PM
JoeNobody's Avatar
Mercedes
I believe that port is just a crank case breather?
Old Jul 29, 2013 | 06:41 PM
macko's Avatar
e55 2005
Now I`m still waiting for new ecu tune,
below pending ECu tune e55.
video of our team
Best Regards from Poland.
https://vimeo.com/60164104
