0-60 time?
It is kind of weird, I tried to do a doughnut one day and turned the esp off and kept it on D, ESP kicked in and I almost hit the sidewalk.
Yes if you put if on first you can do doughnuts, you have seen my video, right? Burning tires Video
But on a cold day if I turn ESP off and keep it on D I can smoke all thru first gear on a straight line with out ESP kicking on.
I'm just wondering what the 0-60 time is for the W210 E55? Is it 4.8 seconds, 5.4 or what?. Does anyone know the 0-62 or 0-100 km'h time? Oh yeah and did the facelifted model affect its performance and has anyone done a burnout in a stock E55? I'm not to thrilled to do one even though I want to (because of the tires). Will winter mode start you off in second gear even if you floor it? Thanks.
For 0-62mph/0-100kmh, MB says 5.7 secs. But again, many Euro mags tested it at around 5.3 secs. The reality seems that the W210 E55 is really .4 secs faster than MB's conservative claim.
Even when off, ESP or ASR will kick back in when the front wheels are not pointed straight during a burnout. My experience anyway.
Try it sometime.
Personal best of 4.8 on G-Tech after ECU upgrade.
Whoa, what ECU upgrade was this? I had to work really hard to get 4.9 secs, even 5.0 takes a perfect launch. But I can usually get 5.1-5.3 secs without even trying.
Perfect launches are almost impossible now!
PowerChip added about 20 peak HP but the midrange HP curve is much fatter. Tirespin from any speed in 1st gear is now a problem
As for the 430 i have the EPS brakes each rear wheel to help the car go straight. If you turn it off it will still work unless you go wide open or "Get Rough" with it. the systems are set up to keep us out of trouble, but if you push it hard enough you can over ride it. We were out one night and got real crazy in my car. After the figure eights and doughnuts and full lock power slides it tripped ever damn light on the car. I had to take into MB and get them turned off and reset. They guy behind the counter goes some one was having a lot of fun
Our with it "OFF" will still clamp the spinning wheel. unless you gas it enough to spinn both at the same time then it will continue to spinn like in the video. Also that car in the videos limited slis is working real well, notice how it is spinning both tires the hole time.
I hate you 55 owners
J/K
No they don't, but I wish they did have it, you can slide in the corners so much better
