Mehanol pre or post IAT vs Killer Chiller. Anyone have either setup?
Old Aug 9, 2013 | 01:25 AM
Max.H's Avatar
E55
I like both setups. Im leaning towards Killer Chiller. But, I'd really like to hear what you guys think of each?
Old Aug 9, 2013 | 01:29 AM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
If your meth setup ever fails or has a problem, you've just blown up your engine. I'm not saying don't do it, I'm just saying there is a very real chance it could go wrong down the line, especially in a DD.
Old Aug 9, 2013 | 01:34 AM
Max.H's Avatar
E55
So true PACougar. Their are some really reliable methanol kits on the market with some really good fail safes. I installed one such kit on a TT C6 and it worked flawless on a daily. Boost dependent and will automatically shut off if any of the parameters fall out of place.
Old Aug 9, 2013 | 01:50 AM
PACougar's Avatar
Even fail safes can fail Don't get me wrong, I'd tune for one I knew was set up properly and I trusted, but it can still go wrong.
Old Aug 9, 2013 | 08:15 AM
chawkins2001's Avatar
2006 E55 AMG
Been using meth for a while now and there is several ways to tune with it, and in the case of failure, there will be no damage done to the motor.
I primarily tuned mine for cooling. We tuned it the following way, got my baseline air fuel to 11.5 without the meth on. Turned my meth on and did another pull on the dyno. The car picked up 16rwhp and air fuel dropped to 11.0..... Then you can also play with the meth mix, the more distilled water you add to the mix, the leaner it gets and vica versa.
Old Aug 9, 2013 | 08:31 AM
RedBullJnky's Avatar
you to Hate
I've been running meh for quite awhile now and I have never had a problem with my set up. BTW I've run out of meth on the highway and on the track (5-6 times) and there is nothing wrong wih my engine.
My nozzles are post IAT sensor and only comes on after 11psi (was running 16psi). Also, I NEVER tuned for it. Cooling only. Gained 72whp after 6000rpms by holding peak power til 7000rpms.
Good Luck!
Old Aug 9, 2013 | 01:49 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I have both a KC and meth...
Go with the meth and log. You will be fine.
Old Aug 9, 2013 | 03:22 PM
black06c230's Avatar
mgLipGD
I have both as well. KC is great for those red light races and around town. Then the meth is great on those hwy runs in Mexico.
Old Aug 9, 2013 | 09:00 PM
Max.H's Avatar
E55
Thanks for the feedback guys.
Old Aug 9, 2013 | 09:24 PM
Denroll's Avatar
'06 E55
^The guy who lowered your car is finishing my meth install right now. He should be calling me any minute to say it is ready to be picked up. Like Craig, Elliott, and Dane, I am running it for cooling. I am anticipating recovering a lot of power, especially up top with the raised limiter. A 100-degree difference in IAT is serious stuff.
Old Aug 9, 2013 | 10:11 PM
PACougar's Avatar
When someone says tuned for meth, that normally means adding a lot of boost(turbos) and or timing. I'm pretty sure you guys didn't do either, correct me if I'm wrong. That's how you blow up a motor. Loosing a .5 point in your AFR isn't going to damage anything.
Old Aug 9, 2013 | 11:36 PM
you to Hate
You are correct sir! I didn't add any timing.
But I will be doing so on my new build.
Old Aug 10, 2013 | 01:53 AM
PACougar's Avatar
Turbo's are cool, you can build in extra safety's via the wastegate.
Old Sep 12, 2013 | 01:15 AM
Max.H's Avatar
E55
Good lord!
Old Sep 12, 2013 | 02:06 PM
bierry's Avatar
E55
May be a dumb question: wouldn't the ECU still pull timing if the nozzle is post (downstream) IATsensor since the sensor would never see the cooler charge effected by the meth? Whereas pre IAT, the cooler charge would be recognized by the ECU and is the only way timing and power would remain intact.
Would love to comprehend the difference. Thanks!
Old Sep 12, 2013 | 06:35 PM
PACougar's Avatar
Yes, the ECU is always going to pull timing if the sensor claims the air is too hot. So if the only nozzle is past the sensor you won't keep the power.
