Took her to the dyno today!
2003 E55 AMG
Took my E55 to a dynojet today, and not sure if I should be happy about my numbers.
Mods are:
-Kleemann headers
-EC smaller s/c pulley
-EC box tune
-K&N
-Larger h/e
-Cm30
-Catless
-Removed resonator
-3in exh to stock mufflers
-Step colder plugs
Numbers were 465hp and 497tq. What you guys think?
Mods are:
-Kleemann headers
-EC box tune
-K&N
-Larger h/e
-Cm30
-Catless
-Removed resonator
-Step colder plugs
05 White Pano E55, Cadillac CTS-V
I have identical mods but also 80mm throttle body. I dynoed less than that with the box tune then after sending the dyno graph with air/fuel in I got a reflash that gained around 30whp. What did the air/fuel look like?
Numbers seem pretty low to me.. I dynoed 435 rwhp and 470 rwtq stock. I have added a smaller sc pulley and tune, but havent been back to the dyno yet. I would think you would be around 500 whp with your mods. Just my opinion though.
OP will be right around 500rwhp with a dyno tune.
A box tune is not helping him and definitely holding back quite a bit of power. OP, I wouldn't be surprised if you gained 30-40rwhp/rwtq from a custom dyno tune with your setup.
Give EC a call!
435/470 is a factory freak in my opinion. Most guys are seeing 390-410 give or take. Torque 440-460. Granted, every dyno is different, conditions etc.
Give EC a call!
Give EC a call!
OP-
That's a lot of mods for only a box tune.
Kansas isn't too far from Houston, is it? Drive down to Houston and have Jerry custom tune that thing. You'll think it's an entirely different car, trust me.
I also dynoed 442/470 stock; well K&Ns, HE & 010 pump type of stock. As was already mentioned, though; dynos can vary.
8-10 hours, roughly
8-10 hours, roughly
Why drive to him? He can easily look at the air/fuel from a dyno graph and look at the rpms of the graph and adjust the fueling and after one reflash have the car way better. That is exactly what he did to mine, and I gained 30+ whp
2003 E55 AMG
Thank you all for your input in the matter. Like urbamworm said, I can email Jerry the dyno sheet and he should be able to adjust from that, which I already have, waiting on his reply. Kind od worries me tho, what if something else is wrong and im losing power? Might have to check my cyl compression's. We shall see what hallens after a retune.
I really don't think you should be concerned, did you get a baseline dyno before mods at that shop? If not you have no comparison data, you simply can't compare others dyno numbers. With a box tune there's a lot left on the table, do you have a graph of the AFR's from the dyno run?
J/K, you are fine and as others have stated you are just running rich ....you will likely need to make a few more tune changes, but keep an eye on AFRs and IATs....
2003 E55 AMG
Damn! only 10k. lol
Yes, I have the dyno sheet, but can't figure out how to upload a pic from my iphone onto here. You guys know? But before wot the afr's are around 12.3 then at wot they stay under 11.8.
Jerry said they're good, so I guess they are. Idk the first of tuning.
When you say they stay under 11.8. do you mean they stay under and near 11.8? If so then you are fine. Go to a track and find out how much power it really makes.
2003 E55 AMG
They're between 11.4 and 11.7, nkt steady tho, they go up and down. But Jerry said yhey look good, so I guess they are.
I took her to the track a while back, with street tires it only ran a 12.4 at 120. Not too excited about that. Maybe I should get some radials or learn to drive her better.
AFR's sound good and trapping 120 sounds pretty close to being right. When you went to the track how were the temps and the humidity?
It sounds like it's performing how it should. Don't ever worry about dyno numbers, unless there from the same vehicle on the same dyno in the same conditions.
2003 E55 AMG
Yea, you're right. These numbers just mean I have to increase, so crank pulley, injectors and tb are next and throw on a belt wrap. Then we shall see.
PLATINUM SPONSOR
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2003 E55 AMG
That's what I've been told. I have Nitto 555's on and I have to leave traction on, if not, like you said, I'll spin like crazy. I am contemplating putting radials on. Im afraid of busting something on launch.
