do you guys go > 10k or under 10k on your oil changes?
Old Jan 17, 2014 | 05:55 PM
  #51
f8l ws6's Avatar
2005 E55
5K - 7K but the closer to 5K the better for me. Probably don't need to worry but cheap insurance I guess.
Old Jan 17, 2014 | 07:10 PM
  #52
AMG55TECH's Avatar
2004 E55, 2003 IS300
Originally Posted by ss.dna02
Anyone use the Fram Ultra? I was at Walmart looking for the Oil and I saw they had that Fram filter. Is it good?
DO NOT USE AFTERMARKET FILTERS!!!!!! Dont get cheap. Either buy the filter from MB/ MB parts distributor/ or buy the Mann filter (our filter is produced by MANN). Ive seen way too many of the cheap filters either not fit correclty (causing oil pressure drop/ oil not being filtered), or ive seen them all mangled, either from not fitting correclty, or just deteriorating and coming appart from poor part quality.
I change mine every 3-4k using Motul 8100 x-cess 5w-40 and a MB/MANN filter. Ill be due to change the oil soon and I will send a sample to BlackStone. Im curious to see how the sample results come back because I have 146,000 miles.
Old Jan 17, 2014 | 08:00 PM
  #53
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Toadster- driving one of these machines on a road course is like no other! I don't show up at a single track event where other drivers aren't surprised that these things absolutely tear it up no problem. Just a little heavy in the turns.....
Old Jan 17, 2014 | 08:09 PM
  #54
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I change every 3-5 K and only use mb filter. Other filters tend to collapse and block oil flow.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 17, 2014 | 09:49 PM
  #55
E55Greasemonkey's Avatar
This place is a joke.
MB filter and Mobil 1 5w/40 every 5k miles. Engine looks spotlessly clean inside. I use the service counter in the cluster...only resetting it every other oil change, so I do the second oil change when it says 5000 miles remaining.
Old Jan 18, 2014 | 12:07 AM
  #56
BenzoBoi's Avatar
Super Moderator
W221
I change my oil every 5k. If there is a track event that I attend, I'll usually change out right after it.
Old Jan 18, 2014 | 02:29 AM
  #57
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
I just did mine at 5k since the last one.
MB filter, and mobil 1 0w-40
Old Jan 29, 2014 | 11:35 AM
  #58
zafarmd's Avatar
clk 430
mobil 1 filter
Is a mobil 1 filter OK for a 2002 clk 430 AMG any suggestions
Old Jan 29, 2014 | 11:47 AM
  #59
Bigtickets's Avatar
That's not an AMG engine. However, I don't think it would hurt. Check on the 430 CLK forum for specifics though.
Old Jan 29, 2014 | 01:05 PM
  #60
Critter's Avatar
07 E63 + 07 CLK63CAB
every 5k and before winter storage, OEM filter, Mobil1 0-40 with and added viscosity modifier specific for synthetic oil. No lifter bleed down issues or ticks on startup. No track time LOL.
Old Jan 29, 2014 | 01:15 PM
  #61
jnash's Avatar
2017 S63
I just run my oil forever until it looks like this, then I sell the car.
http://www.benzworld.org/forums/deta...does-look.html
Can you imagine anyone ever doing that??
  #62
Welwynnick's Avatar
2006 S600
Mobil 1 and an MB filter every 5k - alternating between dealer and home. Changing oil is a pleasure, not a burden.
I don't see why its a waste just because the manufacturer says 10k is OK. They tell us not to change the trans oil or ABC oil! If they wanted to reduce the cost of maintenance, they should reduce the overheads, not the work.
Its my motor and I'll decide how its maintained.
Nick
Old Jan 29, 2014 | 03:44 PM
  #63
Quadcammer's Avatar
96 and 08 911 turbos
Originally Posted by 55fanatic
for as particular as everyone is on this forum, I am surprised you are all using Mobil 1. Especially from walmart since its modified to be cheaper
what is this bull**** you're speaking of?
http://www.bobistheoilguy.com/forums...Number=1564853
Old Jan 30, 2014 | 12:46 AM
  #64
0-60inAMG's Avatar
2004 MB E55 AMG
I always use Mobil1 - 0W40 Euro formula synthetic and fleece filters as well, I drive about 3150 miles per year so it gets changed once per year. I use an extractor and get 8.4 -8.5 qrts out each time and fill with exactly 8.5. It is always clean when it comes out warm to hot.
last change I purchased Mobil 1 - 0W40for just over $5 a qrt at Napa in Bellingham
Old Jan 30, 2014 | 01:24 AM
  #65
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
10,000kms or 6 months for me MB OIL, MB Filter + Liqui Moly Ceratec 300ml.
Old Jan 30, 2014 | 02:03 AM
  #66
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
LOL
I have seen worse actually. An overseas student that had a Celica had his car towed to the shop. The engine threw a rod through the oil pan. When we took off the oil pan the oil had solidified like a cake on the rest of the pan. It was thick not even sludge .. it was solid! Wish I'd taken a photo .. never seen it before.
He also complained the door wouldn't shut properly. When we checked out the rest of the car, it was two cars that had been welded into one! It just wasn't a good day for him
Old Jan 30, 2014 | 02:06 AM
  #67
Originally Posted by turbo97se
LOL
...the door would not shut properly, ya gotta love that!!
Old Jan 30, 2014 | 03:06 AM
  #68
Originally Posted by Toadster
just wondering, I've done 2 oil changes on my car - when recommended...
I've never seen the oil though, and I keep forgetting to do the Blackstone labs checkup...
anyone go longer? do you just change filters more often?
Always do the filter as well, makes no sense to put clean oil in with a dirty filter.
