Front Airmatic went out, had a few questions
2003 E55 AMG
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
Ok so the front left shock went out, its dropped to the ground and makes a leaking/squeaking sound.
1. Now is there a possibility the air hose could be loose or leaky?
2. If it is the shock, then when I replace it is it straight forward like a normal shock assembly. Few nuts on top, one bolt on the bottom and disconnect the air hose? No special tools needed?
3. I plan on buying the Arnott replacement, it seems like the best deal, unless someone knows somewhere better.
Thanks!
Thanks!
You might as well do the other side too while your at it... mine went out a month or so ago, replaced with Arnott they been amazing
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Install a complete set of Arnott air springs for less than the cost of a coil-over conversion and you will have all the advantages of the Airmatic system (with a lifetime warranty) and excellent handling qualities. If you want a road racer, get a Porsche. That said, the addition of toe-links, lowering about 1", balancing the car, KMACS and lightweight rotors make an enormous improvement in handling qualities. After a few turns in my backyard playground (The Nordschleife) I can assure you that you will be impressed.
2003 E55 AMG
I don't really want to do the coilovers I like having the airmatic
The other side was replaced from the prior owner so no need to do that one yet.
So I'm assuming swapping out the strut is straight forward.
2003 E55 AMG
Found the DIY and took out the shock in like25 mins. So far so good now just waiting for my new shock tomorrow.
But I found this sensor thing, wasn't connected to anything and I looked around and couldn't see where it would go. Anyone have ideas?
2003 E55 AMG
2003 E55 AMG
2003 E55 AMG
