--My flat bottom steering wheel.. Almost done--
Haha yeah. I know that feeling well. Disconnect the battery. Two screws in the back to remove the air bag. Undo electrical clips. May have to get a small screw driver to pull up the center clips for the air bag. Unscrew the bolt and she's free. This is for an early W211. Mine is a late model so the bolt is 10mm and the air bag connectors are different.
http://www.macarbon.com/install_guid...structions.pdf
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Dude!
that is just beautiful! I can't wait to get mine done, I've finally got a core. What is that design of stitching called? DCT, right?
No one around here makes the wheel like this... not even DCTM it looks straight up bad *** in person.
#37
Yahh since your fukin foreyes are so out of shape like the rest of you... that's a good assumption!! Move along idiot, i am tired of your sh$it..
and I would appreciate you not makeing any comments on my threads... they are always pointless anyways!!! You just make them ugly since ugly is your thing!!
your lucky I dont live up there or else I would have settled this off the forum, in a different way. I promise
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#38
well went to install the wheel and turns out the wiring pins are a bit different, doesn't look like a big deal but does anyone know a way to wire up the pedals since mine are the 2 wire pins and the wheel comes with the white pin... trying to see if there is alternative ways other than the paddle conversion box
![](http://i631.photobucket.com/albums/uu33/berti_w202/20131010_224739_zps04763259.jpg)
OEM pins
![](http://i631.photobucket.com/albums/uu33/berti_w202/20131010_183034_zps39526848.jpg)
new wheel pins
![](http://i631.photobucket.com/albums/uu33/berti_w202/20131010_175236_zps62596f9d.jpg)
and here is what they made to do it plug and play... but there has to be a way to Wire them even if you dont have that box... anyone know anything plzz share
OEM pins
new wheel pins
![](http://i631.photobucket.com/albums/uu33/berti_w202/AMGpaddleconversionmodule11_zpsf1631b2c.jpg)
#47
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
The paddles look just like the ones in the wife's 12 GL550. They look black in color. Am I correct on that? You got the part # for those?
Wheel looks great by the way!
#50
03 W211 E55
Ok did you do the modification to make them work or did you pay someone to do it?
What exact year/month build is your E55?
I am trying to ascertain if some E55's had different plugs depending on when they were built. I heard a rumour all the 2003's and some early 2004's had one style of plug and the later E55's had another style.
I am interested to know how to do the conversion as well.
Regards,
OZZYAMG
