IAT Battle water-methanol
#76
Received 1,488 Likes
This place is a joke.
Has anyone run a simple, single nozzle before the throttle body inside the factory y-pipe?
Was/is it worthwhile? I'm thinking about doing something like this, cheap and simple, and running 50/50 water/alcohol, simply for cooling without modifying the tune. My thought is this would also affect the A/F ratio less.
#77
#78
If you cool the IAT sensor the ECU will dump fuel and you will actually lose power, seen it happen on the dyno with a killer chiller setup. The ECU thinks its colder than it actually is causing it to add too much fuel. Just a heads up.
#79
CLS55 AMG, ML63 AMG, Cayenne S
Ok, job is done, here are a few pics of where the pump is located, using stock windshield fluid tank (which is rather large), and where nozzle placement, I got the #12 nozzle and it will run at the pumps max (250 PSI) with 50/50 mix, does that make sense?
Pump fits perfectly under the fender. Very happy with the install.
Pump placement
Nozzle is about 8 inches away from IAT sensor, pics of the location
Pump placement
#81
Pump placement
Pump placement
#84
I have to add that I followed Denroll's DIY on what parts to get and what to install. Great DIY!.
#85
For anyone getting an Aquamist kit, this pump location will NOT work as the larger pump does not clear the fender. 1/2" to 5/8" too big
Now to find a suitable tank and run a trunk install...
Pump placement
Pump placement
